which grease gun????????
   / which grease gun???????? #1
whitearrow
philadelphia,ms
john deere 5203
hello fellas.i am in a quandry as to which pistol grip,i think that is the right term,one handed operation gease gun to get.my choices are lincoln,ingersol rand,and plews.what are the differences between the 3 and which is the best as far as reliability and longevity of the product.
any opinions,good,bad or ugly,are appreciated.
thanks,
whitearrow->>>------------>
   / which grease gun???????? #2
All three are pretty good. The Lincoln and Ingersol Rand being the better of the three. Unless your greasing for a living any of the three would probably work fine.
   / which grease gun???????? #3
I have a basic Lumax pistol grip gun with a rubber flexhose and an even more basic other brand gun with a steel hose and long lever. The pistol grip requires a fair bit of hand strength to get the grease into many fittings, and mind you I'm 6' and 240+ lbs, with a lot of hand strength. But it also allows two hand operation on virtually anything. The lever gun is much easier to operate but you would need three hands to work it with a rubber flex hose. Unfortunately a fixed steel hose means I can only get it onto about half the grease fittings on my tractor. I am happy with one of each, and the total for both was under $35. All basic grease guns seem to be practically the same in design and construction.
If I were greasing all the time I would get an electric or pneumatic gun, no question.
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2008 Caterpillar 262C Compact Wheel Loader Skid Steer (A52377)
2008 Caterpillar...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
