Which gear ratio to use?
   / Which gear ratio to use? #1
AlbertC
Perry, GA
New holland 3930
I have a new holland 3930 and a six ft. Bushog. this tractor has 4 forward gears and a H/L gear. When cutting I usually use H 1. I have used H 2 but it seems that if I use this gear it seems that the ride is too rough.
Question is this - is there a "correct" gear that I should be using . For example 4L or is it OK to go with the combination of gears that seems to give me the best cut and ride. I am using to cut pasture grass, usually cut every 3-4 weeks, lots of Bahia in with the Bermuda grass.
Thanks
   / Which gear ratio to use? #2
Go as fast as you can while still getting an acceptable cut.
   / Which gear ratio to use? #3
Keep going faster until the front axle breaks and then slow down a little bit :)
   / Which gear ratio to use? #4
No, there is no "correct" gear.
You should base your gear selection on three things:
1. Run the engine at full PTO rated speed. Often that's around 2500 RPM.
2. Select a gear that lets you run the engine at PTO speed but keeps ground speed down to where you are comfortable and not bouncing out of the seat.
3. Listen to the engine when you have chosen 1 and 2 above. If it's lugging down due to loading from tall or thick grass or brush, go down a gear.
When bush hogging with my old 750 gear drive, I could run as high as 5th (1st High) on light mowing and smooth ground, or as low as 2nd (2nd Low) in thick stuff and even 1st in really heavy brush.
On some fields, I could mow half the round in 5th and then have to shift down for the other half due to thicker grown and/or rougher ground.
   / Which gear ratio to use? #5
I'm OCD. I want a nice, even cut. I look like an old man when cutting because I'm just cruising along at a nice easy pace. My Brother on the other hand paced his speed by how rough the field was. When cutting CRP all he did was bend it over. I hated that. Your speed should be based on the end result and what you expect it to look like. No correct answer.
   / Which gear ratio to use? #6
And that, is the correct answer.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Hays LT1 Tender (A56435)
Hays LT1 Tender...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A57454)
New/Unused 72inch...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
