Which fluid for JD300 hydro transmission
   / Which fluid for JD300 hydro transmission #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
The manual calls for "JD all weather hydrostatic" or type F automotive ATF.
What's in there now is reddish looking ATF.
I'm thinking to drain and replace the filter.
I run Valvoline maxlife (red jug) in my Honda and Toyota cars. Can I use that? I do also use low viscosity hygard in my JD4100.
   / Which fluid for JD300 hydro transmission #2
The red is probably ford type F transmission fluid, its what is called for in the 300 series JD tractors.
   / Which fluid for JD300 hydro transmission #3
If it was my JD model 300 industrial tractor it would receive JD Hy-Gard or it's equivalent that meets hyd oil specifications of J20C. JD 300 brake linings don't tolerate incorrect hyd oil spec's or moisture!
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2014 DIAMOND C TRAILER MFG. (A50323)
2014 DIAMOND C...
