Which fluid for JD300 hydro transmission
   / Which fluid for JD300 hydro transmission #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
The manual calls for "JD all weather hydrostatic" or type F automotive ATF.
What's in there now is reddish looking ATF.
I'm thinking to drain and replace the filter.
I run Valvoline maxlife (red jug) in my Honda and Toyota cars. Can I use that? I do also use low viscosity hygard in my JD4100.
   / Which fluid for JD300 hydro transmission #2
The red is probably ford type F transmission fluid, its what is called for in the 300 series JD tractors.
   / Which fluid for JD300 hydro transmission #3
If it was my JD model 300 industrial tractor it would receive JD Hy-Gard or it's equivalent that meets hyd oil specifications of J20C. JD 300 brake linings don't tolerate incorrect hyd oil spec's or moisture!
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
Claas Rollant 350 Round Baler (A50774)
Claas Rollant 350...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Kubota BX2230D (A47384)
Kubota BX2230D...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
Semi Roll-off 2...
