Which chain saw?
   / Which chain saw? #61
Tractorgirl,
In your "spare time", you might want to do some metal detecting on your property. If it used to be a girl scout camp, no telling what might have been lost over the years. Enjoy your time there and take lots of pictures.
   / Which chain saw? #62
Don't know about the Husky models but the Stihl ones you've indicated are on the smaller size. OK, if that's really what you want. You may be able to get quite a bit more power with only a minimal increase in weight, and sometimes none at all, by moving up a model. Be sure your comparing similar sized models rom each of the two companies based on engine size/output, not similarly priced models. My guess is the Husky models will be a little cheaper - but as the old saying goes, you get what you pay for.
   / Which chain saw?
Thanks for the advice again guys. I am going to the dealer to make sure the weight on the saws will be something I can handle. I'm not a wimp but I also don't want to be in over my head. I like the weight on the Stihl 260 (10.6 vs. 12.1) but I also want to make sure it can perform the tasks we desire. The four I mentioned appear to be comparable in the way of power, hp, etc.
Brent mentioned I should use a metal detector since it used to be a Girl Scout Camp. I believe if I were to use one now, all I'd find are empty beer cans as the teens have claimed it as "party central". However, the mention of camp did remind me of 4-H camp when the counselors would tell stories of how the cooks would roam the woods at night looking for the "mystery meat" for the next day's meals. If they found a camper wandering around, they would be hauled off into the woods never to be seen again. If the Girl Scouts had similar stories, I may find alot of missing girl scouts!
   / Which chain saw? #64
Then you'd just have to work around the crime scene tape. Perhaps you shouldn't look too hard after all.
   / Which chain saw? #65
I have a buddy that still believes in used car oil. I guess it works for him, but I buy the real stuff too. Real bar oil has "stuff" to help it stick to the bar and chain.
   / Which chain saw? #66
I still will restate what I said earlier. Buy one of the Stihl pro-saw models. They make them in smaller sizes as well as larger models. The pro-saws will go forever and have rebuildable engines. The other models are really just a typical consumer-grade disposable product. On the smaller size scale, You may want to look at the 026(028?) Farm Boss pro saw.
   / Which chain saw? #67
Personally I prefer having more than one saw. Given the amount of acreage and the clean up that will be involved, I would look for a quality saw that was on the small side for most of the work and a larger lesser quality saw for the bigger stuff. The larger saws wear me out and that is when I don’t feel safe. It is always that last cut of the day that will get you. My little Echo limbing saw with a 14” bar does 90 percent of my clean up and property maintenance work. When it is time to drop a tree or cut firewood I pull out the larger saw.
Rhonda, stop by anytime, we love to spend everyone else’s money./w3tcompact/icons/smile.gif
MarkV
   / Which chain saw? #68
I agree, and would too if I could afford it. Fortunately, I can use my fathers smaller Stihl when needed.
I have a older Husky that would be in line with the current 385 model. It is large, powerful, and will wear you out when cutting the 1-8" trim stuff. It is awesome for bigger stuff though.
I borrow my Dad's Stihl 024(80's model) for trim stuff. It will also cut some pretty good size stuff, but I like the light weight for all the "general" stuff. For the big stuff, the Husky comes out.
Given some $$$, I would buy one of the newer small Husky or Stihl saws first. Husky has a small pro saw designed for Arborists. It is small, light, and powerful. The ergo's on the saw are great!
For the second saw, I would stay with the same size I have now, in either a Husky or Stihl.
But, remember, this is adding up to $1000 in saws real easily
As a new saw user remember too that she'll need safety gear too. Even for just a single saw, and safety gear, you could easily sink $500 or more. figure a saw, a couple extra chains, bar oil, gas oil, 2-stroke gas can, heavy gloves, helmet/visor/earmuff, chaps, a couple wedges.
   / Which chain saw? #69
I completely endorse everything Jim has said. Buy one of the Stihl pro saws, that is, even numbered model series of your choice. They'll likely out live you.
   / Which chain saw? #70
I have a Stihl 026 Pro (same as current 260 Pro). There have a been a few times I would have liked the 036 for larger trees, but have really appreciated the lighter weight of the 026 for 90% of the tasks at hand. I have a Sears (Poulan) 14" lightweight I have kept around for trimming smaller limbs, but often leave it sitting for the sake of the cutting power and smooth balance of the 026. The Sears saw will be great for my sons to learn saw techniques and safety; otherwise, I would get rid of it. Buy the 260 Pro - you will be smiling while cutting - especially if you have used lesser saws for comparison!
Terry
p.s. my stepfather has a 029 (same as 290?) and everytime we cut together, he says he should have bought one like mine
TEREX TH636C TELESCOPIC FORKLIFT (A52709)
TEREX TH636C...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
