Rotary Cutter Which brush cutter to buy
   / Which brush cutter to buy #11
$2,300 is big bucks for a shredder and it is my humble opinion that you should be able to find a medium duty shredder for about half that. Now, having said that, you must take into consideration it's intended use.... Most medium duty shredders will take a lot of abuse for many, many years... The key word in my post is "medium duty"... Okidokers?
   / Which brush cutter to buy #12
If you are spending a lot of hours mowing on rough terrain, I'd go with Bushhog, Rhino, Woods, or something along that line. Howse even makes a heavy duty. For what I'd call general use (not clearing 3"+ saplings or 15' high brush), you could probably get great service out of KK, Howse, or such. There is a difference in quality in the brands, which is reflected in the price. I would tear up a light duty Howse, but it works great for my father.
I agree. I use a lot of KK but it's mostly to pretend that I'm a farmer on my 10 acres. They work fine for the few times a year I use them. Sure the other brands are better but do you really need them?
The thing I keep in mind is that my wife is awfully nice to indulge me. I don't want to push too hard on our budget.
George
Sorry not to post how I plan to use it.
I have somewhere around 25 acres of timber that I try to mow as many weeds down as possible - probably 3 -4 times per year. I do have an old 5' mower that is workable for the times when I'm in heavy stuff (read that if I'm going to hit something unknown or take down small trees).
My plans are always to be pro-active and purchase something new before the old totally breaks down - thus no emergency purchasing.
As I said in my original post, if I need to save for a few months longer to get better quality then I can do that. My only concern was that the only difference in the mowers was the color of the paint.
   / Which brush cutter to buy #14
Buy the k/k brand and use the heck out of it. What you are describing it will last a long time. For the diffrence in money I can buy some spray paint and touch up once in a while.. I have a 6 footer that has held up fairly well. I had to patch a few welds after 2 days of clearing 2 -4 inch oaks, but hey it did it and I still have that extra cash... I would sugest to find you a used cutter. Many out there with very little use...
   / Which brush cutter to buy #15
I have a couple of 6ft bush hogs. a couple of things I did that really save a cutter is to have a slipclutch on the pto instead of shearbolts. Make sure that the blades are tipped up on the backside so when you do hit something the backside of the blade will hit the deck instead of the cutting edge.
I put 3/8 flatbar down both sides of the deck on the inside, be sure to check for clearance and 3/16th under the deck all around. I have used this mower very rough on right of ways, rocky ground, and have hit just about anything you can imagine. The mower still looks in good shape. I have had to replace a lower seal in the gearbox and several dishes. I have used this mower for at least 15yrs and it is still going.
The things I hate the most to hit are tires and chainlink fence material it really gets the mower to convulsing.
   / Which brush cutter to buy #16
I agree with $2300 seems like a lot for a 5 footer unless you are going into business with it. I looked at low end all the way to the high end and picked what I thought was a good balance for what I was going to be using it for. I ended up with the Bush Hogg Squeeler with a slip clutch.
Now some of you might cringe when you hear this but I have routinly mowed over 8'-9' apple trees with mine (obviously very slowly) and with the slip clutch it seemes to work fine. I really am amazed at what it will do if you take it slow and give it time to maintain a high tip speed.
I can't imagine needing a more robust unit that this one unless for commercial use. I do however need to refinish the blades a bit for this season. (a few dents in the edge to take out and rebalance)
I dont know how much it would be stateside but I paid $1150 for mine in Canada
   / Which brush cutter to buy #17
For sure the bush hog is a better quality than the KK.. however.. the intermittant use you describe.. you will likely giving either mower away with your estate decades down the road. Buy the 900$ mower.. put the other 1400$ in an ira or cd with a long term... you will be dollars ahead...
soundguy
soundguy:
If I put the $1400 in an IRA or CD it might be worth less than $700 of today's $$ in 10 years (smile - that is an attempt at making a joke out of current situation).
For sure I am NOT going into business where I will use the mower on a daily basis. Maybe you guys have talked me into just using the old one I have until it needs repairs. Saving money in this day and age is not a bad thing.
THANKS for all the thoughts.
   / Which brush cutter to buy #19
As long as you hit an fdic product.. even a bad one will get you 2% minimum... ;)
I agree.. if you have a working mower.. work it.
it's not likey they are scarce and if you don't get one now you will have to search for one.
just keep an eye out in the trader papers.. etc.. might stumble on a deal on a new/slightly use done for a couple dead presidents...
soundguy
   / Which brush cutter to buy #20
Go with the KK. And yes, green paint is very expensive in your case. $2300 is way too much for a 60" cutter, whatever the brand!
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
