Which Backhoe?
/ Which Backhoe? #21
D7E said:
JCB had the first .."RIDE CONTROL" and "HYDRO CLAMPS" , built the first tele-handler too ?
And "overlap" their parts like axles, trannies,hydraulics in backhoes,telehandlers .
And you will "NEVER" see a welded boom on a JCB ?
I see a lot of local service departments fixing problems with JCBs. I have 2 heavy mechanic friends who work on them and think they're problematic compared to Deere, CAT & CASE.
My biggest point is there's a reason they have significantly lower resale value than CAT CASE or Deere here in the states. It's because they're not as reliable and not holding up as well and have less dealer support. I just went through the buying process again 6 months ago and used JCB hoes looked like a bargain compared to C,C & D. All the dealers thought that they lacked reliability and dealer support. Let's face it, part of owning/operating a machine is parts & service.
I don't want a urinating match to errupt here, so we might just have to agree to disagree.
/ Which Backhoe? #23
I've been lusting after it for a few days now... Supposebly the 710 deeres of the same era were a more balanced machine but I'd sell my 580 for that bad boy...
/ Which Backhoe?
D7E said:
@ builder ...Don't get me wrong i've been in canada 10 years and i would rate most of your AG machinery above european any day and and am no european "salesman" ..You have good stuff .
All i am saying is an un biassed opinion of backhoes ,We've run 100's of backhoes..Case,Deere,Cat,Ford,Fermec,Hitachi,MF,Volvo,Komatsu,Bobcat ? and there is a top 3 , From an owners and operators point of view .
#1 JCB
#2 CAT
#3 CASE
The others came and went .
I appreciate the bad parts backup that maybe in the states but here in canada its getting better and is only a matter of time ..Government are using JCB now ?
Jcb excavators aint so good ..Nice to use but weak undercarriage ,JCB has always been known for "SMOOOOOTH" movements and visability ?
If you can't drive a jacob you can't drive ?
I hear that too from professional operators about JCB & Cat; another friend loves Fiat Dozers. It's good feedback but for my use (farm and limited contracting - and I do my own maintenance) I have to consider everything: maintenance schedule, durability; strength; then ease of use and speed.
I'll take a slower and clumsier TLB w/ a reasonable maint schedule any day over a fancier machine. There are some incredble deals right now on NH & Terex TLBs. They're awesome to run. But they don't look like they'll take punishment. I have enough trouble w/ the relatively simple electronics on my JD 4310 tractor.
/ Which Backhoe?
D7E said:
Bought it out of protest ...Hired 2 contractors to clear bush and they filled the fires with dirt and left the stumps in the ground and charged me full whack so i got mad and spent a lot of money to prove a point ...Best thing i ever did It's a 180 hp "67" powershift ,24 v start 80% undercarriage ,New chains ,Cylinders new and new transmission ,Full rops ,Angle blade and hyster winch $20'000 ?
Worth more now than i payed for it ...Done the 90 acre clearing job but she's a keeper ?
I loved my D&E also. About the same as yours - and a 1967 - w/ angle blade & winch. But I did some work on it and decided it was too big for me to work on. I got it apart, fixed it, put it back tohgether and sold it.
Also, I got it stuck once and realized I needed something it's size to get it out. My neighbor has an old D8 but it's actually smaller. But I got it out finally and that was enough.
/ Which Backhoe?
/ Which Backhoe? #27
That was the biggest Case ever made, Quit making them when they shut down the Indiana plant in '92 or thereabouts. They share drivetrain pieces with the
W series loaders. The local water utility had one several years ago.
It could flat put a hole in the ground.
/ Which Backhoe? #28
jfh0jfh said:
Yes, awesome. I'd never seen one before. Is that the biggest Case? Too many hours for me or I'd go for a look at it. About 180 miles from me.
I wouldn't be surprised if that machine would go 12,000-14,000 hours, no joke.
If you don't plan on a gazillion hours/yr, give it some thought. If you get it cheap enough and it should ever break, you'll have lots of $$ left over to fix it. If it never breaks, you can laugh at all the jokers driving new $87,000 machines and eating bologna sandwiches for lunch.
/ Which Backhoe?
It went for $15,800. If I'd had time I'd have run over for a look. ~ 3 hours from me.
I don't put on many hours and believe me, a big machine like that is exactly what I'm looking for. But I've had several high-hour machines and I want something a bit newer.
Still, if it hadn't been on ebay I'd have made an effort to go see it. I'm even consdering a low-houir JD 710 - whch is a little bigger than this 780 I think.
There's a 3600 hour unit in AZ for ~ $23K. I emailed them. Too far to ship I thnk but, yeah, it's a great machine.
/ Which Backhoe? #30
The JD710 is one big bad azz machine. You must consider that it will pretty much have to stay put on your farm unless you got a buddy with a big lowboy.
Awesome machine with a 6 cylinder diesel! :eek:
CAT makes a 446 that's massive, too.
/ Which Backhoe? #31
I saw that machine too and was practically salivating over it. :)
Another factor is that with Backhoes, Hours aren't always a sole indicator
of use/abuse. You can have machines that have high hours but not a
lot of abuse, and vice versa. That 780D looked pretty solid for something it's
age, in general.
-Mike
/ Which Backhoe?
age, in general.
-Mike
I think this is a factor with much equipment. You look at a row-crop and a utlity tractor side-by-side. The RC is ready to work at 4000 hours; the utility is worn out - the kidsand the hired guy run it, meintenance is less, no time to warm it up n the winter, ....
It's certainly true w/ backhoes. I've been looking for one for a few months. I looked recently at a 3700-hour Case 580 (worn out); a 2500-hour NH (worn out); a 5500-hour JD (tight); a 6000-hour Case (tight). That's why I always ask about ownership history. Most of the used equipment dealers only know that they got it at auction. (and, yes, I realize that 3700 hours on an older machine may mean 3700 after the 8000 hour-meter was replaced).
/ Which Backhoe?
/ Which Backhoe? #36
Personally, I would get a 580 Case, preferrably a 580K Phase I. Starting with the 580K Phase III (no Phase II), they all have Italian transaxles in them, with integrated shuttle-shift transmissions. Read $$$$$$. The 580C through 580K, Phase I all use the same nearly indestructible and easily repairable rear transmission with a separate shuttle shift transmission. On all later versions it costs at least $8k to rebuild the transaxle, while the earlier versions can sometimes be repaired for < $2k, depending on what's needed.
On the transaxle versions, they use wet brakes, which last a long time, but.... When they need replacing you have to lift the rear of the TLB, loosen the transaxle and then remove the entire stub axle. On the earlier versions, the brakes are dry, and can be replaced in an hour or so.
For TLB that you just want to use and not do commerical work with, the older ones are better, IMO, because they cost less to buy, maintain and there are tons of used parts availalbe when needed.
/ Which Backhoe?
/ Which Backhoe?
Thanks.
1. Yes, I've looked at several Cases (mostly SKs & SLs) but can't find one that I like. When I put them up against something the power just doesn't seem to be there. There are low (3-4000) hour machines so I think it must be me.
2. So right now I'm down to JD & one JCB. I'm not against Case but I have to say that the JDs feel much better.
3. I agree about the older machnes - more electronics = more problems - but there's a balance. A sweet spot if you will. I've had mostly older machines and often spend more time working on them than running them. In principle they're easier to repair but they're also well-worn.
So I'm looking in the 1995-2000 era: JD 310D & E; Ford 655/665/675 D; Case K/ SK & L/SL. No New Holland, no Case SM.
I take your point about the Case transaxle. I did know about that and maybe I should even stay away from SLs. I didn't know the Ks had the Italian unit though. I crawl under all of them and look for the separate units.
Older JDs have wetbrakes and I do prefer them. I assumed any tractor after the mid-1970s would have wet brakes.
/ Which Backhoe?
Thanks.
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
4022CFL (A59228)
4022CFL (A59228)
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
