Which 3pt. logsplitter for tiny 2305?
   / Which 3pt. logsplitter for tiny 2305? #1
fattyfat1
MY DEALER SUCKS, WA
John Deere 2305
looking for a 3pt. logsplitter for my 5gpm hyd. system in a JD 2305. preferably one that can split in both directions. any ideas? thanks, Trev
   / Which 3pt. logsplitter for tiny 2305? #2
I just got one off of ebay they have a number of them on there. The one I got can go horizontal of vertical and came with the hoses. I am not sure on the flow requirements for the splitter though. I think yours would run it but just slowly.
wow, only one person on TBN with a 3pt log splitter huh? i find that hard to believe! oh well, it sucks to be the noob. maybe if i had 1000 posts i'd get some replies
   / Which 3pt. logsplitter for tiny 2305? #4
Perhaps everyone's boycotting your threads until you reinstall your ROPS. We're very safety-conscious here. :)
don't need to re-install, look carefully, it's just folded down. the tractor in that pic is a 4310, i don't even own it anymore.
   / Which 3pt. logsplitter for tiny 2305? #6
Hook the splitter up to a PTO powered hydraulic pump, rather than your tractor hydraulics, and you can run just about any splitter you want.
   / Which 3pt. logsplitter for tiny 2305? #7
You might get more responses if you post in the JD forum.
   / Which 3pt. logsplitter for tiny 2305? #8
Your post count has nothing to do with the # of replies you get...But you did ask two very specific questions that most propably cannot help with:
I personally know of none that will do this...But the Speedco splitter that TSC will work on your tractor but it would be painfully slow.
Youur 2305 does not have 5.2 GPM to operate the splitter, it only has 2.9 GPM for the implements, the other 2.3 GPM from the pump goes directly to the steering system via a priority flow divider. Read this:
Hydraulics
Type Open Center
Pump Rated Output, gpm (L/min.) 5.2 (19.7)
Steering 2.3 (8.9)
Implement 2.9 (10.8)
Pump Type Gear
Maximum Operating Pressure (PSI) 1987
So, with only 2.9 GPM and 1987 PSI I do not think a 3PH unit is right for your machine, unless as suggested above you use a PTO powered pump, but that will add about $400 to the cost of this setup...
There are TONS of posts here about logsplitters, did you do a search?
Hydraulics
Type Open Center
Steering 2.3 (8.9)
Pump Type Gear
thanks, I appreciate the help! this unit, with the power beyond kit, can run a backhoe attachment and not a splitter? I don't see how this could be. this is why I posted in the first place, because i did a search and came up empty handed with this kind of info on small tractors. much appreciated info, thanks, Trev
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
pressure washer, and trailer (A56859)
pressure washer...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
