Where's this Grease Fitting?
/ Where's this Grease Fitting? #41
Re: Where\'s this Grease Fitting?
Please don't tell me that you waited 50 hours to grease your tractor for the first time.
I can't place that last zerc. I don't recognize it. I'm guessing it is up under the dash above the clutch pedal since you can see the smaller power steering hose.
I have gone through several tubes of grease in my 200 hours.
/ Where's this Grease Fitting? #42
<font color="blue">That looks like it's on the front end steering.</font>
This is not correct
<font color="blue"> What I'm interested in finding is the one to the left of the differential when viewed from the rear as shown in the manual. Can't find it. Could only find 2 on the rear of the machine - 3ph lift arm linkage and right arm leveling crank.
</font>
Those are the only two I have found also.
<font color="blue">Sure enought, the clutch and brake zerks are a little tought to reach. </font>
The picture is of the grease fittings tied into the brake linkages. There is one on either side of the tractor. With the FEL mounting brackets there is only about an inch clearance for these two zerks. I think the grease fitting you referred to as the clutch fitting is actually the grease fitting for the brake linkage on the left side. I've found a right angle grease coupler gives easy access to these two grease fitting.
In the picture you'll see the grease fitting tucked in behind the FEL mounting bracket, just about centered in the picture. One grease fitting on the left, the other (not pictured) on the right side.
Don
This is not correct
</font>
Don
/ Where's this Grease Fitting? #45
"Please don't tell me that you waited 50 hours to grease your tractor for the first time"
Nope, but it appears I may have miised a few.
/ Where's this Grease Fitting? #46
Question #4.
Who can tell where this grease fitting is located?
Don
Incidentally...the owners manual calls for greasing every 50 hours.
Question #4.
Don
/ Where's this Grease Fitting? #51
I greased all that I could find on the tractor frame after just a few hours of use. I greased those on the loader and backhoe about every 10 hours or so. But, those on the tractor frame really didn't need much in the first 50 because about 30 or so of those hours were spent sitting still on the backhoe. Only a little steering, wheeling, or 3ph work going on in the break-in period.
That third zerk sure has me stumped - just worried I'm missing something here. I hope the manual is in error. Could it be unique to HST's????
Tom
/ Where's this Grease Fitting? #52
Tom
/ Where's this Grease Fitting? #53
Front right steering ram. Every 50 hours? Wow, I hit these ones every other day. I do a lot of steering and these joints are down low.
/ Where's this Grease Fitting? #54
/ Where's this Grease Fitting? #55
<font color="blue"> Incidentally...the owners manual calls for greasing every 50 hours. </font>
For tractor lubrication that is correct, but the loader manual recommends lubrication every 8 hours of operation.
/ Where's this Grease Fitting? #56
<font color="blue"> For tractor lubrication that is correct, but the loader manual recommends lubrication every 8 hours of operation. </font>
Good find! I looked in the KL130 manual that I have...it states every 10 hours. The 4 fittings behind the bucket need greasing the most. The dirt seems to just suck the grease dry...
Don
Don
HB, Front right steering arm is correct.
Question #5
This should be an easy one to identify the location.
Don
Question #5
Don
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2000 Mack DM690S T/A 2,000 Gallon Water Truck (A66736)
2000 Mack DM690S...
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
