Where's the best place to get roofing
   / Where's the best place to get roofing #11
   / Where's the best place to get roofing #12
Thank you WVBill, you guys have given me some good direction.
Jon
When you call these places, remember they will cut to size, etc. So you have to think it out a bit. Also for a generic pole barn, ask if they have any scratch and dent stuff or an order that was made and never picked up. My BIL saves a lot of money doing this. Sure he may have to make some cuts, but like me, I have a lot of time and little money.
Rob
   / Where's the best place to get roofing #13
Rob
You're right--you have to specify the dimensions of the metal panels (mine are 3ft W x 9 or 10 or 11 ft long) and remember that there is extra material along the overlap edges.
I found that the easiest way to trim the 29 ga metal panels I'm using is with my Makita 4-1/2" angle grinder and a cutoff blade. Zips through that thin gauge material with no problem. I have a power shears, but prefer the Makita for this type of cutting.
   / Where's the best place to get roofing #14
If you have places to hide a carbide blade on a skil saw works ok...loud as heck!!
Also Jonr don't freak out to much on the pricing. The trim pieces, ridge, end caps, drip edge are real pricey compared to the sheets!
   / Where's the best place to get roofing #15
If you use a cutting wheel, brush off the filings. If left on the surface, they will rust and etch into the paint.
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
2000 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2000 INTERNATIONAL...
Unused 2025 CFG MX15RX Mini Excavator (A49461)
Unused 2025 CFG...
