Where would you look for 5th wheel landing gear switch?
   / Where would you look for 5th wheel landing gear switch?
Finally... got time to look closer at this.
Bad ground...!
Cleaned up a couple of the ground connections, and it works like a charm. Funny thing is, only thing affected was the front jacks...
I checked the switch voltages with a volt meter; got 12V. Checked with a test light, no light. Checked from chassis ground; 3.6k ohm...
   / Where would you look for 5th wheel landing gear switch? #12
I'd get a rubber boot on that switch, ASAP...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58374)
KNOW BEFORE YOU...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2015 UTILITY VS2RA...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
