Where to split tractor
/ Where to split tractor #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
IMAG0462[1].jpgIMAG0463[1].jpgI have a broken shift fork in the back of this transmission so I have to remove it. Can I split it at the back where the two transmissions come together, where the cover is removed or do I have to split it at the engine as well?. I just split it last week to put a clutch in it and that was a blast. It's a Farmtrac DT300 or a Montana 3040 or an LS c3030, all the same.
Got a little further on it today. I found a large nut that backed of a gear and a broken shift fork on the front/ reverse shift railIMAG0473[1].jpg. Also the reverse gear syncros were eaten away as well as 1/2 of the reverse gear itself.Apparently there was a lot going on in this gearbox.IMAG0472[1].jpgIMAG0466[1].jpg
It looks like I have to split it in both places this time to get the gears out.
/ Where to split tractor #3
Yeah, that calls for a full teardown, bummer. Do you think the backed-off but was the cause? Wasn't it staked or wired? Best luck.
Jim
/ Where to split tractor #5
I couldn't make out the broken shift fork, in the first bottom picture, if that's the rear gear syncro, the back corners do look knocked off. What do you think would cause a shifting fork to break and gear damage?
I can picture a 100 parts being taking out, bolts, gears and the very important shims and where they go, hope you have a shop manual or something to go by, good luck.
John Deere 2755 Tractor w/ Boom Mower (A66285)
John Deere 2755...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
1143 (A63745)
1143 (A63745)
