Tiller where to lubricate
   / where to lubricate #1
john carr
Greenup, IL
Tractor King 254 and iseki
Help, I have an older (2000?) Caroni model fl 1400 tiller. The top gear-pto attachment box has a fill hole on top and a drain hole on the front bottom. Dip stick has two marks near bottom. I assume the bottom mark is the lower operation ( need to add fluid ) and the top mark is the full line. What weight of gear fluid should I use?
Next question concerns the drive chain on the left side( viewed from rear). Their appears to be fill plug on the lower back of the cover and a second plug located on the front of the cover about mid-height. Do I use the top hole to fill the cover until fluid runs out of the bottom hole?
Now for the bearings on the tiller shaft? Left side could be lub'ed with the drive chain. But I can not find any place to lub on the right bearing.
Thanks in advance for anyones help.
John Carr
2009 Dodge Ram 3500 Flat bed (A55973)
2009 Dodge Ram...
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
2022 FORD E350 BOX TRUCK (A57880)
2022 FORD E350 BOX...
UNUSED FUTURE CAT 305 EXCAVATOR AUGER DRILL (A57193)
UNUSED FUTURE CAT...
2011 FORD F350 SERVICE TRUCK (A57192)
2011 FORD F350...
2017 CATERPILLAR M316F MOBILE EXCAVATOR (A52707)
2017 CATERPILLAR...
