Tiller where to lubricate
   / where to lubricate #1
john carr
Greenup, IL
Tractor King 254 and iseki
Help, I have an older (2000?) Caroni model fl 1400 tiller. The top gear-pto attachment box has a fill hole on top and a drain hole on the front bottom. Dip stick has two marks near bottom. I assume the bottom mark is the lower operation ( need to add fluid ) and the top mark is the full line. What weight of gear fluid should I use?
Next question concerns the drive chain on the left side( viewed from rear). Their appears to be fill plug on the lower back of the cover and a second plug located on the front of the cover about mid-height. Do I use the top hole to fill the cover until fluid runs out of the bottom hole?
Now for the bearings on the tiller shaft? Left side could be lub'ed with the drive chain. But I can not find any place to lub on the right bearing.
Thanks in advance for anyones help.
John Carr
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
1263 (A50490)
1263 (A50490)
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
John Deere 637 Disk (A50514)
John Deere 637...
