Where to get Quick attach plates
   / Where to get Quick attach plates #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I need QT plates or mounts for the implement side of the QT.
I see some on Ebay. I like the two seperate plate style for a loader bucket.
Anybody on TBN make these or have a source?
   / Where to get Quick attach plates #2
I had a Bobcat skidsteer at work and wanted to put a 7 foot western plow on it.
I asked the nearest Bobcat dealer if he had the QA plate. He did and it was about $135 or so.
It was very easy to put the plow onto it and it hooked right up like any factory QA imp would
But it was the one piece plate
   / Where to get Quick attach plates #3
Here is a link to the ones that I have used and they fit well and I would buy them again. KFI QA PLATE
or KFI
   / Where to get Quick attach plates #5
I bought a QA plate off Ebay. Sorry cant recall the company. But the bottom cut outs were a tad too small and I had to grind them out a little to get them to fit right. Took about 1/2 hour with 4 1/2" grinder and a couple of cutting wheels.
Looking to get another one when I convert my snow plow to skid steer mount for the tractor.
Wedge
Thanks for the replys guys.
   / Where to get Quick attach plates #7
I think everythingattachments.com sells them and it could even be with free shipping.
   / Where to get Quick attach plates #9
I made my own. First sets I made I sent a fab shop drawings for water cutting and forming (break). I welded the top piece. These turned out very nice. Depending on the quantity you want done this might be an option for you. I can send you drawings if you want them.
I have since made attachments (pallet forks) where I integrated the QA with the frame of the attachment. This saves some weight that you don't need - especially with smaller tractors.
For cost, I would suggest you make your own. 1/4 inch flat stock, drill bit and jig saw and you will have the rectangular cutouts done in ten minutes. When you install them well gussets to support the ends.
Here is a pic of a QA plate that I had water cut and formed; search for "tractor side QA", I detailed my builds there.
   / Where to get Quick attach plates #10
In case someone wants to make one.
  • Bobcat quick attach plate.pdf
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
