Where to get large diameter PVC pipe or tubing
   / Where to get large diameter PVC pipe or tubing #11
I don't know about the pond liner, but the rubber roofing (I have some) would not work as a slide. Not unless it was close to verticle. It is not slippery - at least dry. Maybe oiled up it might work, but that gets a little kinky.
   / Where to get large diameter PVC pipe or tubing #12
Irrigatio/sprinkler, and underground utility companies deal in plastic pipe the size you need.
Soundguy
   / Where to get large diameter PVC pipe or tubing #13
I'm not sure, but I think the pond liner and rubber roll roofing are about the same material, aren't they? (EPDM?)
SHF
   / Where to get large diameter PVC pipe or tubing #14
I had a similar idea last year and talked to a sprinkler/irrigation company. They wanted $400 for a 12' piece of abs pipe (I think it was 18" dia).
Cheaper to buy a roto-molded slide from a playset supply company, similar price but you get a nicer looking finished product.
   / Where to get large diameter PVC pipe or tubing #15
We did a state prison job a while back, and they had two different types of "rubber roofing". One was the Firestone or Carlisle EPDM black stuff you see all over the place. But on the kitchen roof, the roofing was white in color, and more slippery than snot on a doorknob. We went on this flat roof a few times, and it was real slippery even from dew in the early AM. I was on it once when there was some slushy snow, and it was a challenge to stay on my feet. The contractor said it was a different composition because the black material wasn't as resistant to the grease that would end up there from the kitchen exhaust h fans....................chim
   / Where to get large diameter PVC pipe or tubing #16
I don't know how you'd connect them but you could find a few of those 55 gallon plastic drums. Split them from top to bottom and heat weld them some way. I see them for sale around here on the side of the road for around $15 or so each.
   / Where to get large diameter PVC pipe or tubing #17
We have a water slide at our "Over the Hill" party every summer. We use a long narrow tarp, can't remember where we got it. See attached pic.
Thanks for the ideas. Now that I have some ideas to look for, I'll have to get to some places and start looking at what they have.
   / Where to get large diameter PVC pipe or tubing #19
At our church camp, we used mine conveyor belting. They change it out fairly often and roll it up. When wet, it becomes very slick. If the curves are gradual enough, you can even put banked turns in.
UNUSED JCT DUSTLESS BLASTER (A51244)
UNUSED JCT...
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
Swamp Buggy (A49346)
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
Hays LT1 Tender (A52128)
Hays LT1 Tender...
