Where to get 3 point parts
   / Where to get 3 point parts #1
dougg
Bronze Member
I picked up a seeder on a tool bar, but it's just a bar without any lower or upper hitch pins. I need a 3-point "triangle" that clamps or welds on to the tool bar. Anyone know where to buy one?
   / Where to get 3 point parts #2
We have an Agri Supply locally that I buy all that kind of stuff from. I built a set one time but they mass produce them and by the time you count your time, materials, wear on drill bits....some things are cheaper to buy and I find these arms fit in that catagory.
Most any farm equipment dealer will sell parts to fix it but the bigger chain dealers should be cheaper.
You also can do like I do on a lot of my small equipment. I have a trailer mover hitch, (reciever tube hitch) for my tractor. It has that triangle already made. Cut you a piece of 2"X2" square tubing to correct length and weld it on to the seeder, and then work it out of your reciever hitch. When you're done, pull one pin, slide it out and use the hitch for something else.
   / Where to get 3 point parts #3
   / Where to get 3 point parts #4
WOW, they want 229.00 for the reciever hitch now. I've built 3-4 of them, gave one to a buddy. I have 2 old hitches taken off of trucks I bought for 10.00 each. They cut down and adapt real easy.
dougg, that is the style hitch I was talking about. Get one of those and then weld your seeder on a piece of tubing to slide into that hitch. Lots of uses for the hitch after seeding.
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
iDrive TDS-2010H...
