Where to get 10k lb tie downs?
   / Where to get 10k lb tie downs? #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
Hi, does anyone know of a good place to get the nylon (or whatever material they are made from) tie downs? I need them to be at least 10,000 pound rated and 25' -30' long. I know TSC has some but I was hoping to find some online to compare. Thanks.
   / Where to get 10k lb tie downs? #2
27' Wide-Handle Ratchet
Buckle Strap Assembly
The industry standard for flatbed cargo control.
10,000 lb. Breaking strength.
3,300 lb. Working load capacity
27' Wide-Handle Ratchet Buckle Strap Assembly
27' Wide-Handle Assembly- Strap Assemblies-------------------------
Product# 1-5 Clayton Supply
27RATCHET 27' $ 26.00
Clayton-Supply…Straps
   / Where to get 10k lb tie downs? #3
Robert,
I believe that you can find what you are looking for at NorthernTool
   / Where to get 10k lb tie downs? #4
http://www.agri-supply.com. Page 60 in their catalog, look just like the ones JMIII posted, are 10Klbs 2"x27 ft. and $19.95 ea.
   / Where to get 10k lb tie downs? #5
I got my 10k lb, 30 footers at Sams club for $13 each. DOT rated and JD yellow. /forums/images/graemlins/smile.gif
   / Where to get 10k lb tie downs? #6
Saw some at Sam's Club like those in the above post. About $12.50 each.
   / Where to get 10k lb tie downs? #7
Northern Tools has them and they also carry replacement straps.
I know cause i am going to have to order some . i had one snap while trailering my tractor . i have since gone to chains and binders for the tractor.
Did anything happen when your strap snapped? I only use chains and binders while hauling our equipment. But when we haul wire the chains damage the wire too much so the straps are better for that.
   / Where to get 10k lb tie downs? #9
I had two other straps holding the tractor so it didnt move. i just tied the broken one togather and retightened it.
The chains do scratch the paint where it binds but i can touch up paint. i am thinking of getting some heat shrink for the chains to prevent the scratching.
I have been told that any fraying on the straps can cause it to fail. it doesnt take much to fray them.
That is something I have never worried about. I put more scratches on my tractor then what the chain does. Plus, I bind the front where the axel piviots and in the back I bind off a clevis attached to the drawbar (so any scratches do not show anyways). Have never had a problem and I haul my tractor all over the county. I have always had my doubts with straps because I didn't like the idea of something that can tear holding my tractor down so I only use them on something that needs the delicate touch that chains lack.
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2022 Mack MD Danco 12R22 22FT Rollback Truck (A50323)
2022 Mack MD Danco...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
