where to find used hay wagon?
   / where to find used hay wagon? #1
clarkfarm
WNY
TC24DA, 12LA FEL, 60"MMM
I'm in WNY, been looking for a 4 wheel hay wagon, without luck. Any ideas would be appreciated. thanks
   / where to find used hay wagon? #2
Local farmers, farm auctions, ad in the local rural papers.....
   / where to find used hay wagon? #3
Don't think they cost that much new>
Egon /forums/images/graemlins/grin.gif
   / where to find used hay wagon? #5
Where are you located? I assume you are looking for a flat rack hay wagon. Send me a PM and I might be able to help find you one.
   / where to find used hay wagon? #6
</font><font color="blue" class="small">(
Egon /forums/images/graemlins/grin.gif )</font>
that is dependent on what you think they should cost. To buy a new running gear you are looking at at least $1k. Then you need to buy tires for it or scrounge some up and get them mounted if you can't do it yourself. If you have to buy flotations you then start looking at over $1500 for just the running gear that can now roll. Figure out what your wood will cost to build the deck, and if you want to figure in your time you are close, if not over, $2k for a simple wood decked wagon /forums/images/graemlins/tongue.gif
I find used running gears all the time though that can be bought from anywhere between $20 to $1k (nice heavy tandem jobs). The $20 gear I bought and gave to my neighbor. It needed one wheel but otherwise was in great shape. It was an old Allis Chalmers gear. I tossed one of my spares on it and hauled it down the road with no problem and it had sat in the weeds for a couple years. I would have liked to keep it but my neighbor has been good to me and asked me to find him one if it was cheap enough. So I helped him out and hopefully I will find that good of a deal again but I doubt it.
For as simple as these gears are I have no idea why they cost so much new.
Thanks for the response. I am in Orchard Park. Looking for a flat top, four wheel type to haul and display pumpkins and christmas trees. hoping to get one for $300-500. not sure what they go for.
   / where to find used hay wagon? #8
A farm auction is probably the best place to get one. No farmer is probably going to bid against you--they are practically obsolete as far as regular farm use goes.
   / where to find used hay wagon? #9
</font><font color="blue" class="small">( A farm auction is probably the best place to get one. No farmer is probably going to bid against you--they are practically obsolete as far as regular farm use goes.
)</font>
4-wheeled "hay racks" sell like they're made of gold to all the farmers in this neck of the woods. Still as common as ever. Hay, straw, and even tobacco farmers use 'em. They sell at prices unheard of a few years back. Whenever I get a chance to buy one cheap, I latch on to them. (I've got 5 of my own)
Good ones with running gear rated 8 ton or heavier usually bag $600 or $700 at the lowest, and I've even seen a nice 10 ton gear with good bed sell for $1250 last summer.
They're sure not obsolete here!
   / where to find used hay wagon? #10
Ok then, you are not that farm from me. There were 3- 5 ton wagons at an auction this summer then went for around $150-$200 each. They were nothing spectacular but they were in good shape. I will ask around and see what I can find.
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
Informational Lot - Financing (A53472)
Informational Lot...
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
8x12 Custom Built Greenhouse (A51573)
8x12 Custom Built...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
