Where to find SYP lumber in SW PA?
   / Where to find SYP lumber in SW PA? #31
Any building in my township needs to be code compliant, so I absolutely need to use dry graded lumber for my secondary framing. No way to design for proper deflections without it.
Back to the original topic, based on earlier advice I’ve managed to source SYP from Menards in Tridelphia. Sincr I’ve already posed question of SPF go by building designer, I’ll wait for that answer. If possible I always prefer to buy local, and SPF is a lot lighter and easier to work with.
BTW LD12, I figured out why we were misaligned with our figures. The AWC span calculator shows adjusted Fb values, which take into account factors like size, spacing, and use cases to modify the base numbers that are in the tables. So based on that, you’re totally correct that for certain size (particularly 2x6 and 2x8), SPF does have a higher bending strength for grade #2.
I appreciate everyone’s input
As you have found out, it is pretty difficult to just find a generic chart that shows Fb, and E values of common graded lumber. But those are just one piece of the information.
It would be nice to know the anticipated wind and snow loads the engineer is designing for.....was well as the spans and spacing. Cause then you can simply plug those numbers into the calculator.....and choose the size, grade, and species of lumber you are thinking and see if its acceptable.
For example....when I built by barn....which was a common 2x6 stud wall on top of a block foundation....I also opted to add a little loft for storage. 8' loft. The "joists" for the loft needed to span 8' minus the triple 2x12 beam they were hanging on. So a ~7'7-1/2" span for the joist. So I was faced with a decision on how to do the joists to get to my design target of 100psf loading.
On 12" centers, a #1 SYP with 100# live and 5# dead load was rated to span 7'11"
#2 SYP was only good for 7'7"
#1 and #2 SPF were both only good for 7'7" as well.
IF I went to a 2x8,
#1 and #2 SPF would span 7'11" on 19.2" centers
#2 SYP Would only do 7'5" on 19'2" centers, so would need to drop to 16" centers to get 8'2" span
And #1 SYP would span 7'9" on 24" centers.
So armed with this info I could have used:
#1 SYP 2x6's on 12" centers
#2 SYP 2x8's on 16" centers
#1 OR #2 SPF 2x8's on 19.2" centers
#1 SYP 2x8's on 24" centers.
So there are many ways to skin the same cat and be okay. Higher grade lumber....different spacing, or upsizing from 2x6 to 2x8 or from 2x8 to 2x10, etc all has an impact on the final strength of the structure.
At the end of the day, I decided to go with the #1 SYP 2x6's on 12" centers. At the time they were actually cheaper than the standard #2 SPF 2x6's at menards, even though they were special order. Going with the 2x8's would have been more per board but needed fewer boards. SO it was a wash.....pennies difference. So I decided on the 12" centers so I could sheath the floor with cheap (at the time) 7/16 OSB rather than go to thicker OSB suflooring like 3/4" thick stuff.
I use that AWC wood calculator alot. I dont focus too much on the FB or E or any other designations for lumber "strength". Because those only tell part of the story. I input a set of parameters, select a board, and see its rated span. Choose a different board and look at its rated span. Because the rated span takes into account ALL the variables of the lumber. And if a board is rated to span farther, it can safely be assumed it is gonna be stronger than one rated to span less. Just like I have mentioned in your scenerio.....with 12' spans....enter some parameters. Then play around with 2x8 SYP #1 and #2, and SPF #1 and #2 and without changing the loading or any other parameter other than grade and species....and see which one is rated to span farther. For example....L/360, 40/5 psf live/dead, 24" centers.....2x8's.....
#1 syp = 11'2"
#1 and #2 SPF the same at 10'9"
#2 syp weakest at 10'2"
Thats what I meant by "play around with" that calculator.
Based on your spans, and a close estimation of loading....#1 syp is gonna be the strongest. SPF (either 1 or 2, no difference) is gonna come in second. And #2 SYP is the weakest. So if your engineer simply specs #2 OR BETTER SYP......well I'd classify both #1 and #2 SPF in the "OR BETTER" category since it is stronger/capable of farther spans
   / Where to find SYP lumber in SW PA? #32
Many/most companies in the pole barn business deal with code compliance all the time.
402 (A52706)
402 (A52706)
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
Case IH 875 Disc Ripper (A59814)
Case IH 875 Disc...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
