Where to find specs on gray market Yanmars, and advice on towing with dump trailer.
   / Where to find specs on gray market Yanmars, and advice on towing with dump trailer. #1
TacticalAnt
Yanmar TBD
Im looking at buying a gray market Yanmar with FEL, im trying to find info on lengths and weights so i can plan for a trailer to haul it with. Not a lot of specs on the gray market ones. Also, the trailer will be a 6x12 dump that ill be hauling it in. 12’ is the longest i can go as my max weight is 10,000 gvwr. Towing with a 2nd Gen tundra. I suspect one with lower sides so i can chain the tractor down easier? Thoughts and advice?
   / Where to find specs on gray market Yanmars, and advice on towing with dump trailer. #2
I recall that sometime ago, someone posted something about an owners manual or a service manual for a gray market tractor and the only thing found was in Japanese. I suspect the forum was either here or Green Tractor Talk and further, I can't recall which or when.
Not sure if this is relevant to your situation but it may be an obstacle you might encounter.
Good luck.
Sounds like the situation i had with a JDM toyota Hiace i owned. Fortunately google had an app that i could use the camera to scan the Japanese and it would instantly translate to English.
   / Where to find specs on gray market Yanmars, and advice on towing with dump trailer. #4
If anyone needs free manuals and the largest knowledge base on the internet for Yanmars, come to the YTOG.
Thank you, subbed!
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
