Where to find specs on gray market Yanmars, and advice on towing with dump trailer.
   / Where to find specs on gray market Yanmars, and advice on towing with dump trailer. #1
TacticalAnt
Yanmar TBD
Im looking at buying a gray market Yanmar with FEL, im trying to find info on lengths and weights so i can plan for a trailer to haul it with. Not a lot of specs on the gray market ones. Also, the trailer will be a 6x12 dump that ill be hauling it in. 12’ is the longest i can go as my max weight is 10,000 gvwr. Towing with a 2nd Gen tundra. I suspect one with lower sides so i can chain the tractor down easier? Thoughts and advice?
   / Where to find specs on gray market Yanmars, and advice on towing with dump trailer. #2
I recall that sometime ago, someone posted something about an owners manual or a service manual for a gray market tractor and the only thing found was in Japanese. I suspect the forum was either here or Green Tractor Talk and further, I can't recall which or when.
Not sure if this is relevant to your situation but it may be an obstacle you might encounter.
Good luck.
Sounds like the situation i had with a JDM toyota Hiace i owned. Fortunately google had an app that i could use the camera to scan the Japanese and it would instantly translate to English.
   / Where to find specs on gray market Yanmars, and advice on towing with dump trailer. #4
If anyone needs free manuals and the largest knowledge base on the internet for Yanmars, come to the YTOG.
Thank you, subbed!
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
Elgin Pelican Street Sweeper (A55851)
Elgin Pelican...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
