Spreader Where to find PTO shaft with key on implement end?
   / Where to find PTO shaft with key on implement end? #1
dwhite
Bronze Member
Broadway, VA
Kubota G1900s, B-7610, L-5240
I have a Massey 160 Spreader that needs a new PTO shaft. It is a 1" with keyway on the stub that is on the implement. The PTO shaft will need a 1/4" key. I ordered what I thought was correct from Agri-Supply but it's wrong--has the keyway, not the key. I priced one at a local tractor store (before ordering from ASC) and the price was over $250. Any ideas where to get this for less than $250.
   / Where to find PTO shaft with key on implement end? #2
Your new shaft is probably correct. Both the shaft and yoke will have keyways; the key is a separate part. Either a square or woodruff key depending on the cut of the input shaft.
Anyone that retails A&I products or you can buy online by searching All parts store and choosing a dealer. The parts will ship to you. I have done part of the search for you:
AllPartsStore Search results for (Miscellaneous) Driveline Driveline Assembly
   / Where to find PTO shaft with key on implement end? #3
Yep......you need a piece of keystock and cut to size (if its a straight key). Or as mentioned, the correct size woodruff key.
Got a picture of the keyway on the input shaft of the spreader? NAPA carries both woodruff and straight key stock.
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2000 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2000 KOMATSU...
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
