Where to find plans for building a Run-In shed for my horses???
   / Where to find plans for building a Run-In shed for my horses??? #11
Well, people will cringe, but those structures ended up pretty solid for the purpose. Remember to build according to the sheets, That means the metal roof too. All material was from the local HD. I used screws on the metal. The run-in is pretty tall. I am 6-2" so it was probably 14-16 feet up in the front.
Riptides,
VERY HELPFUL PIX!
I've been getting stuck on the following...
anchor/foundation - How deep, how many, and how long do those posts need to be?
I used a manual post hole digger. So they were not as deep as they should be. But I probably sank the posts in at least 3 feet. I don't use 4X4's over 12 feet. I had one warp on that equipment shed, did not brace it up in time, had to take it out. Dry concete into the post, water can, pack.
As they set up, I did the horizontal braces. Working up, if I came across a short 4X4, I'd add on to it. Those too long, chain saw. Notice the 4x4's are "wrapped" with 2X4's - added strength.
roof - rafters or??? How many supports?
Same principal for roof. I used 2x6's for the rafters. Horizonal 2X4's so the metal could be attached without me missing the wood. The rafters looked to be every 4 feet spaced. Maybe 6 from the middle in that one pic. Engineering flaw? :)
opening - How to span the opening and still hold up the roof? How big of a board, how big of an opening?
The shed opening is at least 12 feet. The sides of the opening give it away, pure no cut 4X8 T-111. I probably used a 2X6 as a header, going from 4X4 post to post. Remember the 4X4 posts are wrapped with 2X4's so it all matched up for strength and a smooth finish to lay the T-111's on. The horizontal bracing instead of verticals, makes nailing a fun and easy task. If you miss, well... no comment. :)
Walls - 24" studs or 16" studs? As I can see in your picture, NO STUDS! I like that idea!
I am also planning to set this right in the corner and use one side and the back in place of fencing (attach the fence directly to the shed in one corner).
Yeah, these had to go up quick, and they had to somewhat last. They did. The horse run-in is positioned to where the afternoon sun starts creeping in. Kept in nice and dry. Never saw a horse in it, but had to clean it out on ocassion.
I agree it is 100% a math problem, and I keep over engineering it...
I only have 2 horses now, I intend to have 4-5 max someday.
Thanks,
David
Good luck, you can do it!
   / Where to find plans for building a Run-In shed for my horses??? #12
I have had good luck with 16 oc for rafters, crossing 2X4's and metal roofing- snow slides off quickly. You are getting the storms we used to get in Maine! The killer is when you get 2' of snow, then it rains the next day! 1 in 3 slope roof will leak, I like 1in 4 or steeper.
It is always exciting to build. There are no right or wrong ways, but you do get better as you go along!
Virginia
Use IBC 2003—10 psf-25 psf with Case Study Areas at higher elevations
—And—
Contact Local Building Officials for determining required Snow Loads
psf (pounds per square foot)
http://www.fs.fed.us/t-d/snow_load/states.htm#maine
HERE should give you some ideas...
Artisan,
I really liked one I saw with a tack room on the side. I am now considering something like that.
Thanks,
David
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
International 4700 Vibra Tiller (A51039)
International 4700...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
UNUSED FUTURE 12' X 7' CONTAINER (A51244)
UNUSED FUTURE 12'...
