Where to find Mobil 1 Delvac syn in Ontario??
   / Where to find Mobil 1 Delvac syn in Ontario?? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
I am having a hard time finding Mobil 1 Delcav 1300 oil in Ontario, Canada. Can anyone help?
I just came back from Harrisburg, PA, and could not find it there.
Can I use regular M1 synthetics in our MF1523?
What about Petro-Canada's line of Duron synthetics??
TIA,
Will
   / Where to find Mobil 1 Delvac syn in Ontario?? #2
I use regular Mobil 1 5w30 in my JD and in my 1983 Benz diesel. Next change, I plan to switch all vehicles to the new Mobil 1 0w30 except maybe the Benz. Will reread the owner's manual on it to see if the 30 grade is okay in it, but I have some 5w40 Mobil 1 to change it already anyway. I change them all every fall.
Ralph
   / Where to find Mobil 1 Delvac syn in Ontario?? #3
For the synthetic Mobil One Turbo Diesel ag oil, you can find it at a distributor of Mobil products and expect to pay the long dollar because of limited demand.
A better way, if you are looking for the synthetic oil is to look for Mobil One Turbo-Diesel ( I thnk it's 5W40) synthetic oil at WalMart in gallons. I understand it to be the same as the Delvac synthetic but repackaged for wider consumer use and mass marketed. I use it.
I also use Rotella sythetic (@ WMT) and it's fine and I have used Deere 0-40 synthetic (sometimes marked "semi-synthetic" but is full syn)
Regular Mobil One is probably not rated for use in your tractor. Look in the owners manual for a rating and compare to your oil can rating. Do a little searching. Synthetic is so much easier on the engine.
Let us know how you make out with this.
I was doing some research at Canadian Tire, and noticed that they sell Red Line Oil . I am gonna go that route.
Thanks to all who replied.
Will
   / Where to find Mobil 1 Delvac syn in Ontario?? #6
Hi Will,
I picked some Delvac1 this Spring from Noco, in Etobicoke, ON.
NOCO Lubricants Canada, Inc.
Not cheap.
I had a Mobil 1 link that indicated Mobil 1 Truck Turbo Diesel was the same as Delvac, but it has been removed. Could be re-formulated (?), or they don't want to erode their margins on Delvac.
Rgds, Dave.
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
