Where to find Mobil 1 Delvac syn in Ontario??
   / Where to find Mobil 1 Delvac syn in Ontario?? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
I am having a hard time finding Mobil 1 Delcav 1300 oil in Ontario, Canada. Can anyone help?
I just came back from Harrisburg, PA, and could not find it there.
Can I use regular M1 synthetics in our MF1523?
What about Petro-Canada's line of Duron synthetics??
TIA,
Will
   / Where to find Mobil 1 Delvac syn in Ontario?? #2
I use regular Mobil 1 5w30 in my JD and in my 1983 Benz diesel. Next change, I plan to switch all vehicles to the new Mobil 1 0w30 except maybe the Benz. Will reread the owner's manual on it to see if the 30 grade is okay in it, but I have some 5w40 Mobil 1 to change it already anyway. I change them all every fall.
Ralph
   / Where to find Mobil 1 Delvac syn in Ontario?? #3
For the synthetic Mobil One Turbo Diesel ag oil, you can find it at a distributor of Mobil products and expect to pay the long dollar because of limited demand.
A better way, if you are looking for the synthetic oil is to look for Mobil One Turbo-Diesel ( I thnk it's 5W40) synthetic oil at WalMart in gallons. I understand it to be the same as the Delvac synthetic but repackaged for wider consumer use and mass marketed. I use it.
I also use Rotella sythetic (@ WMT) and it's fine and I have used Deere 0-40 synthetic (sometimes marked "semi-synthetic" but is full syn)
Regular Mobil One is probably not rated for use in your tractor. Look in the owners manual for a rating and compare to your oil can rating. Do a little searching. Synthetic is so much easier on the engine.
Let us know how you make out with this.
I was doing some research at Canadian Tire, and noticed that they sell Red Line Oil . I am gonna go that route.
Thanks to all who replied.
Will
   / Where to find Mobil 1 Delvac syn in Ontario?? #6
Hi Will,
I picked some Delvac1 this Spring from Noco, in Etobicoke, ON.
NOCO Lubricants Canada, Inc.
Not cheap.
I had a Mobil 1 link that indicated Mobil 1 Truck Turbo Diesel was the same as Delvac, but it has been removed. Could be re-formulated (?), or they don't want to erode their margins on Delvac.
Rgds, Dave.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
