Where to find install manual for 62D on my 2520?
   / Where to find install manual for 62D on my 2520? #1
Deadman
WI
John Deere 2520, X475
I recently bought a used 62D MMM for my JD 2520 and would like to know where to look for installation manual, any suggestions?
I found that one, but I didn't know if there was a different manual for actually installing the mounting brackets to the tractor itself? I bought a used 62D and its coming with all the brackets, but I just wanted to see if there was a sealer install manual for the first time install to put brackets on the tractor itself?
I'm hoping all the brackets are with my mow deck when it arrives, but I would like a manual to determine if all the parts are there before I start installing things. I would rather have the extra parts needed on hand before I start installing it, but if not I can see how it goes after it arrives.
Thank you for the link!
   / Where to find install manual for 62D on my 2520? #4
There were a few different versions of the mower lift kits 2520.
You can find the parts lists at John Deere - Parts Catalog
Just need to figure out the lift kit that you have.
   / Where to find install manual for 62D on my 2520? #5
You will have to get the "install" manuals from JD I believe.
   / Where to find install manual for 62D on my 2520? #6
Here is a copy of the installation instructions.
  • 2520 mower lift.pdf
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53473)
Chevrolet C8500...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
