Where to find install manual for 62D on my 2520?
   / Where to find install manual for 62D on my 2520? #1
Deadman
Veteran Member
WI
John Deere 2520, X475
I recently bought a used 62D MMM for my JD 2520 and would like to know where to look for installation manual, any suggestions?
I found that one, but I didn't know if there was a different manual for actually installing the mounting brackets to the tractor itself? I bought a used 62D and its coming with all the brackets, but I just wanted to see if there was a sealer install manual for the first time install to put brackets on the tractor itself?
I'm hoping all the brackets are with my mow deck when it arrives, but I would like a manual to determine if all the parts are there before I start installing things. I would rather have the extra parts needed on hand before I start installing it, but if not I can see how it goes after it arrives.
Thank you for the link!
   / Where to find install manual for 62D on my 2520? #4
There were a few different versions of the mower lift kits 2520.
You can find the parts lists at John Deere - Parts Catalog
Just need to figure out the lift kit that you have.
   / Where to find install manual for 62D on my 2520? #5
You will have to get the "install" manuals from JD I believe.
   / Where to find install manual for 62D on my 2520? #6
Here is a copy of the installation instructions.
  • 2520 mower lift.pdf
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
