Where to find a used aerator?
/ Where to find a used aerator? #1
AceDeuce
Northern Virginia
Kubota BX1500 w/ R1's and LA181 FEL
I'm looking for a USED aerator for my BX. Preferably it needs to be 48"-60" wide, 3PH mounted, and non-powered. Whether it is a core type or a spike model doesn't really matter. However, I am interested in a reasonably stout unit - none of these flimsy Home Depot jobs (they are not 3PH mounted anyway).
The trouble is, I can't find any! Those that I can find are either new (can you say "sticker shock"?), or ridiculously high priced for used equipment. Any suggestions where to look?
/ Where to find a used aerator? #2
You may try a dealership that also rents equipment or a regular equipment rental yard.. One of the local JD dealers had a very stouch core aerator that was pull behind.. It looked like a very heavy duty one you can get at lowes/home depot/northernn tool. He wanted over $600 for it out of his rental fleet..
Im not sure if you have tried the box store aerators, but they can do a pretty good job.. I used a Sears ~48" core aerator on saturday (after getting about 2" of rain on Thurs/Fri) and it did an excellent job with only 106 lbs of weight.. I got about 1 to 2" cores, and it left the holes opened up very nicely for my grass seed and fertilizer to fall into.. lol
good luck
Brian
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
