Where is you Temp sending unit? - L series
   / Where is you Temp sending unit? - L series #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
Got an L2500 with the 3cylinder engine. I've added amp and oil pressure to the tractor and poked around and couldn't find a spot for the temp sender. Where is your located? Block, near the thermostat? Is the Kubota temp gauge electric or a mechanical gauge.
I promise this is my last change. /forums/images/graemlins/grin.gif
Thanks,
Rob
   / Where is you Temp sending unit? - L series #2
It should be screwed into a water jacket on the block. I haven't had to look for mine for an exact location but that is where manufactures install them.
   / Where is you Temp sending unit? - L series #3
I have a 2 older B series tractors and on the the forward side of the cylinder head on the RH side ( as sitting on the seat) there is a plug that goes into a water jacket ( it looks more like a hex head bolt 14-15mm). I have removed and tapped it for an 1/8" npt. That is what most of the sending units use. It has worked well for me.
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A50860)
2018 Mack PINNACLE...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
