Where is the hood release for a MF 1529?
   / Where is the hood release for a MF 1529? #1
tmajor
Platinum Member
NE PA
2010 MF 1529, Woods ZTR MZ1952, National Mower sickle bar circa 1963
Bought a MF 1529 last Sat, to supplement my Ford NAA. While, I can get the hood open from underneath, I notice a cable attached to the release latch, but, for the life of me (without tracing it back), can't find a hood release knob among the many others. Where is it?!!
   / Where is the hood release for a MF 1529? #2
It is located by the front right wheel. The cable is the hood release, there is no knob on anything else near the operator station if that's what you are thinking. Just pull the cable and raise the hood. Let me know if this doesn't help and I'll take pictures.
@DuckSlayer1017 Thanks! That's what i had been doing, but upon seeing the cable, suspected it headed toward the operator's station. I guess, a cable/knob could be added, if so desired.
Well, there is a "pull knob" for opening the hood .... It's just a small black plastic thing, sticking out of the frame on the right side, directly outboard of the latch. It wouldn't do much good, if the latch was bit rusty.
   / Where is the hood release for a MF 1529? #5
Another 1529 owner....welcome to the forum. I picked mine up this year, late spring, and have enjoyed the heck out of it. Looking forward to seeing how it starts/runs this coming winter here in northern Minnesota. This is the first diesel I've owned.
The MF 1529, which I bought, is a pretty clean tractor, 530 hours. However, I believe it spent most of it's life out in the weather. Many of the parts were seized, due to rust/oxidation, ... i.e. the draft bar stabilizers wouldn't turn, seat arm rests wouldn't move at all, wheel lugs required an impact tool to break them loose, etc.. The hazard/turn signal lights were wiped out ... one was totally missing.
I found, that buying parts for the MF is quite cumbersome, compared to the Ford NAA, which has a multitude of sources.
So, my efforts so far, have been getting things loosened up, changing fluids and filters and paint touch-up. Otherwise, it seems to be a solid tractor.
Additionally, I shortened the top section of the ROPS by 16", as it stuck up so high, I couldn't get it into any of my buildings, without folding it down. It's still over a foot higher than my head.
   / Where is the hood release for a MF 1529? #7
Arizona, I'd get a oil pan heater or block heater before winter. I am getting one this year to help with the cold starts. Mine always fires right up but she does huff and puff for a little while. Other than that mine runs great in the winter.
   / Where is the hood release for a MF 1529? #8
I have a 1,000 watt block heater, factory (or dealer) installed. Good to hear your 1529 starts OK in the winter....hopefully mine will be just as cooperative.
   / Where is the hood release for a MF 1529? #9
Block heater update: We had 21F degrees earlier this week. I went out and plugged in the 1529 for an hour, then used the glow plugs for 5 to 6 seconds, then cranked it over. It started great. No sputtering, no white smoke....it was just like a hot start in mid-summer. I realize 21F isn't close to cold, but I'm fairly confident that 1KW heater will do what is needed once the snow is on the ground and temps are sub-zero.
How do you expect it would have done without the heater?
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2024 BRAZOS 53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
Massey Ferguson 9250 (A52748)
Massey Ferguson...
