Where is the filter for hydraulic/transmission fluid on 2640 1980 year model
   / Where is the filter for hydraulic/transmission fluid on 2640 1980 year model #1
Xjbrian1
Sulphur springs, tx
Jd 2640
Where is the filter for hydraulic/transmission fluid on 2640 1980 year model ?
I was told to remove a bolt under right side.
I read online to drain Trans fluid then clean a screen you get to after removing a 1/2" plug.
A diagram would be appreciated.
Thanks.
   / Where is the filter for hydraulic/transmission fluid on 2640 1980 year model #2
Hyd filter from JD AR75603 Filter Element ADD 7.96 USD
Trans screen is parts key #30. Hyd filter bolts up at the bulge in trans case between parts keys #26 & 27(1st photo)
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
Two Transmissions (A50325)
Two Transmissions...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
Drome Excavator Quick Coupler (A50325)
Drome Excavator...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
