Where in the world is my HST oil filter located
   / Where in the world is my HST oil filter located #1
nykyfyr
Lake George NY
Kubota B2710
Changed the transmission oil on my B2710 and could not locate the filter for the HST. Can anyone help.
Thanks!
   / Where in the world is my HST oil filter located #2
<font color="blue"> Can anyone help. </font>
Have you checked your manual? It should tell you exactly where it is.
   / Where in the world is my HST oil filter located #3
Are you looking for the HST or Hydraulic filter?
When sitting in tractor seat the HST filter is on the left side forward of the rear axle.
B2710 with a serial number less than 50101 do not have a Hydraulic Filter.
Some B2710 with the lower serial numbers were modified and have the filter.
If your tractor has the hydraulic filter it is on the right side about the same location as the HST filter.
It is a different filter than the one for HST.
67955-37710 Trans/Hyd Filter For tractor serial number 50101 and up. $11.11
66021-36060 Filter, Spin On HST Trans. $10.35
The SN for my tractor is a little over 15,000. So the early B2710's do not have two filters? I reviewed the flow diagram in my WSM and could not locate a filter where one should be. So that must explain it. MAN I am really glad I found this site. Thanks for all the help!!
   / Where in the world is my HST oil filter located #5
</font><font color="blue" class="small">( So the early B2710's do not have two filters? )</font>
Yep, like Ron said, I had an early B2710 with only one filter but don't forget that it has two strainers; one on each side.
2021 Allmand Bros Maxi-Lite II S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
