Where does grease come out?
/ Where does grease come out? #1
Rail Dawg
When you're doing the greasing of the 3 pedal shaft zerks on a L3800 where does the grease come out when you're pumping grease into the middle zerk?
All the other ones I can tell when to stop but not the middle one. I could hear above it some sounds likes grease was coming out but I couldn't see it.
Thanks.
/ Where does grease come out? #2
Thanks.
Sorry I don't know your tractor so can't answer the question. However when greasing a machine, it is bad practice to keep doing so until you can see the grease - over greasing attacts dust into the joints causing the lubricant to actually work as a cutting / grinding paste.
If you grease the machine at regular intervals in accordance with the operators manual, 3-4 pumps of the grease gun should be plenty - same prinicipal as if you had an auto-lub unit fitted.
The only exception I make to this rule is on machines which are already badly worn - where the benefit of the additional grease outweighs the risk...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
Caterpillar CP-563/CS-563 Parts and Service Manuals (A63117)
Caterpillar...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
MASSEY FERGUSON 2605 TRACTOR (A64280)
MASSEY FERGUSON...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
