Where do you store your attachments?
   / Where do you store your attachments? #41
that's what I am planning on adding eventually. A 10 foot overhang of the side of my 32' barn. I should be able to get everything under there except the backhoe which unfortunately will always have to be left outside due to its size. I will probably double up one of the beams I use to construct the overhand and weld a tab onto the PGD so I can just hang it instead of leaving it sit on the ground.
   / Where do you store your attachments? #42
Mine are stored inside a pole barn. I just got some pallet racks, the racks are 10' tall 42'' deep and 8' wide
   / Where do you store your attachments? #43
Mine are stored inside a pole barn. I just got some pallet racks, the racks are 10' tall 42'' deep and 8' wide <img src="http://www.tractorbynet.com/forums/files/attachments/402835-where-do-you-store-your-barn-racks-003-2-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/402836-where-do-you-store-your-barn-racks-003-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/402837-where-do-you-store-your-barn-racks-006-2-jpg"/>
looks good, very organized.
   / Where do you store your attachments? #45
i just reciently installed rack shelving in my place also. but not for implements.
   / Where do you store your attachments? #46
   / Where do you store your attachments? #47
I've often thought that this would be a great way to store implements if I had a barn or shop.
I don't have any doubts anymore, that looks great! Where did you get the shelving units?
Craigslist, they are used.
6 10ft x 42'' Uprights,
26 8 ft Cross Beans
26 Wire Decking
The reason I originally asked was because, until this year, I had all of my attachments stored inside. But now I don't have the room anymore. DW decided she wanted to use our gazebo for entertaining instead of using it as a storage shed. So my FEL and counterweight have to stay outside. I have them covered with heavy plastic and tied down. The front blade and snowblower are inside where they are fairly easy to get to when the snow comes. The tiller is also inside because of the rotating aspect of it.
Next year when the greenhouse is built, it will give me a place to store all the summer outdoor stuff that has added up.
   / Where do you store your attachments? #49
Looks great, I want do do this in my polebarn, just need to get some pallet racking.
   / Where do you store your attachments? #50
The only problem I'm having is the backing plate / safety plate is in my way, it's to close to the trusses, when I load the top shelf.
I should have order it without the plate
2015 KENWORTH T680 SLEEPER TRUCK (A54313)
2015 KENWORTH T680...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR3DDBZ7701 (A54865)
2013 Freightliner...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
200356 (A51406)
200356 (A51406)
