Where do you park your tractor when not in use, inside/outside/Covered outside?
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #11
I keep mine in the barn during the winter, easier to plug in that way, during the summer I keep it outside.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #12
stored in un-heated shed year round. Power available so I keep a NOCO battery charger connected in winter. Out of sun and rain and battery always ready to go in spring.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #13
I kept my diesel mowers and tractor in a shipping container for 20 some years. Now they all reside in my 30x32 pole barn.
I can't stand the thought of parking equipment outside.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #14
I keep mine in a heated garage at 50 degrees, no worries and ready to go.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #15
I keep her parked in a garage, though it doesn't have a door. So, it's out from the rain, but it's not ideal.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #16
Three different spots, all under roof. WM75 with the horse trailer and Mule, TC40DA on one side of the shop, and the 25S and ZTR on the other side.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #18
I feel bad when I leave mine in the un-air conditioned part of my barn. :p
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #19
After ten years outdoors;built a 24x32 pole barn three years ago.Unheated but at least out of the weather and plugged in for the winter.Battery tender and block heater when needed.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #20
I used to store mine under a roof, open sides, although the loader hung out in the weather. Now at the new house, I dont have a covered area yet, so it's in the weather.
Does it matter? I know my old Kubuta would absolutely get water in transmission around the gear shifter boot. So, it does matter some.
I will note, Kiotis paint isn't very durable, so maybe cover is needed, and I plan to construct something soon-ish.
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
