Where do I find spring latches like this?
   / Where do I find spring latches like this? #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
OK all you DIY's; I found this in Northern but I'm really looking for one with a longer throw. Any ideas?
   / Where do I find spring latches like this? #2
From McMaster-Carr, of course.
Link
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
You will have to add the spring yourself, it looks like.
Mike
   / Where do I find spring latches like this? #3
web page
Google search for spring latches. First hit.
My kubota has several like that on the mmm mower attachment.
Egon
Egon
Awesome! Way to go guys! I searched with Altavista without much luck... never use Google but I noticed a lot of guys here do; I'll have to try it...
McMaster - Well of course I thought of them! Everything I found didn't have the springs though but I never even saw the page linked here. The problem with McMaster is they have SO many things, you almost have to have the exact terminology they use to find anything.
Thanks to both of you! (Project photos to follow!)
   / Where do I find spring latches like this? #5
</font><font color="blue" class="small">( The problem with McMaster is they have SO many things, you almost have to have the exact terminology they use to find anything.
)</font>
When the new printed catalog arrives, I usually spend a couple of hours just going through it, page by page.
If you want confusing, you should see the catalog that the University's Central Stores uses. Glass is grouped with Paint, but plexiglass is Hardware, Bolts are Machine Screws, Drywall Screws are grouped with the Metal Studs , I can't remember where Tapcon screws are, but I know they are not with the rest of the anchors.....It makes sense, IF you know where to look.
   / Where do I find spring latches like this? #6
Saw them at home depot yesterday . They were about 18 in. long
   / Where do I find spring latches like this? #7
You can always make one to suit your needs...there real easy to make.
Chad
   / Where do I find spring latches like this? #8
This is not to you MikeIA but to the moderator MikePA... I have seen your advice posted several times but it sure isn't clear to me...
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}Enter words here{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
- What is the {/url}?
- What does the last senctence refer to? I don't see any parentheses only brackets
Has a FAQ tab been considered where topics like this could be explained in detail with examples? others might be attaching photos, searching for topics, and saving favorite threads.
Thanks for the info ...sorry to be somewhat slow
   / Where do I find spring latches like this? #9
They really are simple and fun to make. The attached pic is one I made for my trailer. I used a 1/2" anchor bolt, clamped it in a vice then heated the bend area red hot and made a simple 90 degree bend. Next I cut to length, drilled the holes and added a spring.
The big advantage of making it yourself is you get exactly whats needed for the intended purpose, and like I say its fun! /forums/images/graemlins/grin.gif
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
John Deere 1025R (A53317)
John Deere 1025R...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
