Where do I buy Hydraulic hoses with ends on them.
   / Where do I buy Hydraulic hoses with ends on them. #1
nvlong4n1
Eastern, NC
Is there a website where I can specify the hose size, length, and hose ends and have them made and the ship to me I found a few that will sell the hose or the ends but not an assembled hose with ends.
Thanks,
Nelson
   / Where do I buy Hydraulic hoses with ends on them. #2
Here is a thought that if you buy hose by the roll ie 25' or 100' and put on your own ends. Then you can have any lenght any time.
Craig Clayton
   / Where do I buy Hydraulic hoses with ends on them. #3
I get certain lengths made up from Surplus Center (sponsor here too).
Also, a search should bring up a member that I recall making up hoses to size.
Have you tried the search?
   / Where do I buy Hydraulic hoses with ends on them. #4
Discount Hydraulic hose advertises they will make a hose with any end you want. I sent them a RFQ yesterday. I try to make my own hoses but the selection of reusable ends is very limited and becoming expensive.
Crimp on ends and bulk hose are quite reasonable. It's the crimper that becomes an expensive problem .
   / Where do I buy Hydraulic hoses with ends on them. #5
I know someone that got a hose made up at TSC and the price was quite reasonable.
   / Where do I buy Hydraulic hoses with ends on them. #6
My local auto parts store will make up a hose with connectors. I brought one in from my case and they built a hose the same day.
   / Where do I buy Hydraulic hoses with ends on them. #7
Ill make them and send them to u. Just drop me a pm.
   / Where do I buy Hydraulic hoses with ends on them. #8
Our UAP makes most size types of hose and at reasonable prices.
The odd time they lack the actual fitting but usually can do a work around.
   / Where do I buy Hydraulic hoses with ends on them. #9
It's nice to see we've already been mentioned here. We can make up just about any hose you need. Your charges will be the cost of materials plus $10 per hose assembly ($12 if your hose is longer then 15 feet).
I am working on a way to automate the ordering process for our web site, but for now, the easiest thing to do is call in or email. If you find the materials on our site, you can also order the hose and fittings online. Then, use the comment field at checkout to tell us what you want made into hose assemblies.
23013 (A53421)
23013 (A53421)
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
1-Pallet Brake Chambers (A53117)
1-Pallet Brake...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
