Where can I suggest improvements to manufacturer
   / Where can I suggest improvements to manufacturer #1
dakota-2000
I have a 5600C Turbo with 200 hours on it. I blew a valve stem out by hitting a branch on the ground. Scared me half to death. There is only one other TC in my area but every skid steer I checked since had at least one and sometimes more metal screw on valve stems as a replacement.
Also the bracket that holds the oil reserve tank to the frame under the passenger is so light weight that it broke within a few hours use. I had the bracket welded and a plate welded under the oil tank to help support it. I suppose TC isn't going to worry about that as the new "D" will have the engine there. Should get delivery on a "D" in a couple weeks.
   / Where can I suggest improvements to manufacturer #2
As far as the valve stem goes - __it happens. I wouldn't call that a manufacturing problem. Skid steers may have metal ones because of how then move. Then skid and more prone to hitting something on the side of tire/rim. Some skid steers will even have a metal ring welded around the stem to help protect it.
The weak oil reservior bracket may be a legitimate complaint. Probably just a poor weld.
The skid steers I saw had some of the rubber stems replaced with metal stems. Evidently they have blown out the rubber stems. I would think if Bobcat knew there was a problem they would correct it. I just wanted to know if there was a place to voice suggestions other than the dealer.
The reservoir bracket broke just beyond the mounting bolt, no weld near.
   / Where can I suggest improvements to manufacturer #5
The D has the really short metal valve stems.
TC is getting smarter. Thanks
CATERPILLAR 908M WHEEL LOADER (A52707)
CATERPILLAR 908M...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
TANK MANIFOLD (A55745)
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2010 Ford F-450 16ft Box Truck (A55852)
2010 Ford F-450...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
