Where can I buy sheet metal?
   / Where can I buy sheet metal? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I need a flat sheet of metal to cover a wooden tool box and for various other occasional projects. Corrugated roofing is available at a reasonable price but the flat metal that I've found is sky high. Does anyone know a good source. I'm near the point of trying to flatten the corrugated stuff.
   / Where can I buy sheet metal? #2
Speedy Metals will ship
   / Where can I buy sheet metal? #3
Look up a roofing distributor in your area. If they don't stock what your looking for they should know of a local sheet metal shop that will shear and break if you desire any kind of sheet metal you want. They should have 26 ga to 16 ga as well as 032 alum .
   / Where can I buy sheet metal? #4
Go to a sheet metal shop (HVAC} or a supplier they'll have whatever you need.
   / Where can I buy sheet metal? #5
Depending on the size of the pieces you're looking for, I'd suggest your local recycling center. They may have a lot of old duct work and stuff you might be able to pick out what you need and pay just a little more than what they gave for it.
   / Where can I buy sheet metal? #6
This. Most any competent HVAC shop should be able to help. Lots of flat sheets of galvanized metal.
Thanks guys. You've given me some options I hadn't thought of.
   / Where can I buy sheet metal? #8
If you have a local source for corrugated, just ask them for metal BEFORE it is ran through the corrugator/former. It can be cut to length.
   / Where can I buy sheet metal? #9
How big of a sheet is needed? You can get galvanized HVAC sheet at Lowes/HD for pretty cheap. I think they have 36"x48" sheets for about $8 if I remember right.
My local source is Lowes and I think the roofing is corrugated when they get it.
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
JOHN DEERE HX14 LOT NUMBER 226 (A53084)
JOHN DEERE HX14...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2014 GMC Sierra (A51692)
2014 GMC Sierra...
(INOP) JLG 36AM-DC VERTICAL MANLIFT (A51247)
(INOP) JLG 36AM-DC...
