Where can i buy rim guard/beat juice in bulk?
   / Where can i buy rim guard/beat juice in bulk? #1
Fields_mj
Central Indiana
Ford 1710, Kubota F2880, White FB16
Title pretty much says it all. I want to put ballast in my tires and they hold 70 gal each. I'm thinking 55gal drums would be ideal. 2 barrels would give me 1200 lb of Ballesteros which should be plenty.
   / Where can i buy rim guard/beat juice in bulk? #2
I put washer fluid in mine. Way cheaper than beet juice.
You must have some large tires to take 70 gal. each. Mine took about 37 gal. each.
   / Where can i buy rim guard/beat juice in bulk? #4
Quick search found one site with RG, nearly 1700 for a drum. Might check with these guys and see if it's a good alternative.
17.6x24. Chart says they you'd 70 gal ea, but 55 should be more than ill ever need. Last time I did one it was an 11.2x24. Pretty sure those hold around 33 gal. Cost of having the shop put beet juice in was only about 10% more than another shop down the road wanted for washer fluid, but that was a few years ago.
   / Where can i buy rim guard/beat juice in bulk? #7
The alcohol they put in windshield washer fluid to lower its freezing point can destroy rubber tires. Whether it's methanol or ethanol. It causes the rubber to soften, swell and then become brittle.
   / Where can i buy rim guard/beat juice in bulk? #8
Also check into this product. It’s non corrosive, won’t freeze, and less messy than beet juice. It’s what my dealer uses.
Bio-ballast is very likely another sugar based concentrate based on the SDS at your provided link. SDS flash point ( decomposition point ) for sugar is 365'F per Bio-ballast SDS is ">375'F" and pure sugar degrades at 365'F or 185'C per Crystal Sugar SDS.
Bio-ballast SDS
Pure sugar SDS
I don't know about either Beetjuice ( Rim Guard) or Bio-ballast being less messy as they are both examples of waste product that would normally go into animal feed instead being repurposed and sold at a much higher profit as wheel ballast.
Bottom line is they both provide the highest density, with anti freeze properties, wheel ballast available. Both require the solution to be warm, either done in warm weather or heated, as they are very thick in cold weather and much harder to pump in thru that small tire valve. Tires are filled with valve at high point and fill stops when solution runs back out valve. This prevents filling a tire till its solid and provides an air cushion when driving over a raised object.
Bottom line. Shop around for either Rim Guard or Bio-ballast for least expensive installed or drummed product as they are essentially identical but from different organic feed stock
ps. My M59, bought used out of PA and shipped to NC, came with RimGuard but not listed as feature during sale. I discovered filled rear tires when I tested air pressure and purple juice sprayed out due to valves not being at highest point.
   / Where can i buy rim guard/beat juice in bulk? #9
I'd think you've already seen their web site, but...
You can contact them for a dealer near you, but I found an industrial tire place (rather than farm tire shop) that did mine for me pretty cheap. IMHO, it's not a DIY job.
   / Where can i buy rim guard/beat juice in bulk? #10
Bio-ballast SDS
Pure sugar SDS
My dealer though it was made from corn so you guess is probably pretty close.
AIRMAN COMPRESSOR (A45333)
AIRMAN COMPRESSOR...
2017 FORD F-350 (A45333)
2017 FORD F-350...
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
2019 Ford F-250 Super Duty 4x4  6.7L Turbo Diesel, Tow Package (A44789)
2019 Ford F-250...
2013 Ford F-150 Pickup Truck (A44572)
2013 Ford F-150...
2003 Ford F-150 Pickup Truck (A42744)
2003 Ford F-150...
