Where are the "older" LS Tractors?
   / Where are the "older" LS Tractors? #1
jaydee325
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
It is understandable that as time moves forward, the newer tractor experience and questions predominate. I'd like to hear from the several year old crowd.
Purchased my R3039H in July of 2013. It has been a great tractor. It does everything I need it to and I've not had any major issues. Only one minor one that was quickly handled by my dealer who has been great.
Let's hear it from the 2 or more year old crowd!
   / Where are the "older" LS Tractors? #2
I bought my XR3037HC in Feb. 2014 so 2 1/2 years old now. It does have the tier 4 Shibaura engine and not the Mitsubishi interim engine of previous models but its still running fine and hasn't been back to the dealer for any problems. Only about 110 hours.
   / Where are the "older" LS Tractors? #3
Re: Where are the "older" LS Tractors?
I bought my 4041 EZ-Shift in 2011. Have about 380 hours on it. Interim Mitsubishi motor. No problems with mine whatsoever.
   / Where are the "older" LS Tractors? #4
Bought ours in 2014 from TSO.
   / Where are the "older" LS Tractors? #5
I have a 2013 R4041 Hydro. 350 hours, Mitsibushi engine. I had a small coolant leak when new and the dealer fixed it promptly, no problems since. I have done a lot of work clearing land and removing stumps, hauling logs, and moving lots of dirt. Very, very happy with my LS. :cool2:
   / Where are the "older" LS Tractors? #7
I've owned my XR4046HC since December of 2014. Both front hubs have been replaced due to bearing failures. Fuel tank was replaced because filler neck crack. All done under warranty with no issues. Have been completely satisfied with tractor. Just turned over 400 hrs. today mowing.
   / Where are the "older" LS Tractors? #8
Bought a U5030, in 2011. Has the S4s Mitsubishi 3.3 engine. Replaced a battery. Has about 300hrs. No issues. HS
   / Where are the "older" LS Tractors? #9
2010 S3010
(Or 09 bought in 2010)
S4L powered,,485hrs,,,has been rode hard and put up wet since I bought it.
3 oil changes,1 hydro change.
It's spends most of it's time drag'n a 6ft Bush hog through 4.5acres of bermuda grass,,discs and hips the garden every year,,(6ft disc-1 row hipper) and has built several shop and house pads with a 5ft box blade.
Had 1 major malfunction when I first got it,warranty covered it and all was good!
Just finally tracked down my loss of power,not wanting to recover and regain rpms after it gets lugged down pretty hard,,,
Fuel cap not venting properly anymore,,,
Me the drill and a 1/4" drill bit fixed the problem.
Good lil tractor!
Wish they still made them with the S4 series motors.
   / Where are the "older" LS Tractors? #10
It is understandable that as time moves forward, the newer tractor experience and questions predominate. I'd like to hear from the several year old crowd. Purchased my R3039H in July of 2013. It has been a great tractor. It does everything I need it to and I've not had any major issues. Only one minor one that was quickly handled by my dealer who has been great. Let's hear it from the 2 or more year old crowd!
The oldest LS tractors in the USA will be green and have Montana on the sides.
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
2008 UTILITY DRY VAN TRAILER 53X102 (A57880)
2008 UTILITY DRY...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
John Deere 1025R (A53317)
John Deere 1025R...
20357 (A55758)
20357 (A55758)
