Where are my seat spacers (BX24) ?
   / Where are my seat spacers (BX24) ? #1
Hedgy
CT
BX24
Scattered on my property no doubt. Anyway it's worth checking the central nut under the BX24 seat support for tightness. Mine was loose and further inspection revealed 3 of my 4 plastic seat spacers missing, and one of the steel balls was also bidding for freedom.
The parts manual shows two nuts and a regular washer should be on that bolt. I've only ever noticed one bolt. I've now replaced the washer with a lock washer.
It seems that gravity and seat pressure is meant to keep the four spacers in place at the corners of the seat support plate, but if the seat gets loose they probably stick to the seat and get pulled out during use, especially when rotating the seat to operate the backhoe.
Has anyone else improvised those spacers or thought about methods to retain them? Perhaps by screwing a washer into their underside?
They cost around $5 each - not a big deal if I replace them once but I don't want to keep losing them.
For reference the part number is K2591-56670 SPACER TURN SEAT.
   / Where are my seat spacers (BX24) ? #2
I just had the same problem last weekend. I went to lift the seat to flip to BH mode and the seat came off in my hand. I had also lost 1 of my spacers.
Thanks for the part number, sure will come in handy.
   / Where are my seat spacers (BX24) ? #3
Just this past weekend I replaced the seat on my bx23 and noticed one of the spacers was loose and out of its hole and caught up under the seat frame. Didnt lose it, but probably only a matter of time before it wiggled out from under the seat frame. Guess I was just lucky to be replacing the seat when I did. Not sure that this had anything to do with it, but just prior to this, I noticed the seat was getting harder to lock down into position after using the backhoe.
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2015 Honda Civic Engine (A50325)
2015 Honda Civic...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
