Where’s the best place or way to increase performance with a chainsaw.
   / Where’s the best place or way to increase performance with a chainsaw.
This thread wasn’t about a sharp chain or not. It was about modifying the saw and how much power is really to be gained. And I’m pretty sure the carb on my saw needs adjusted rather I decided to mod the saw or not. It starts harder than it used to and doesn’t seem to reach as high of rpm as it used to. It also seems to smoke a little more.
   / Where’s the best place or way to increase performance with a chainsaw. #12
Get best quality sharpener you can afford.... (Not HF piece of crap) ... Many chains sharpen at different angles and such, make sure any sharpener has ability to adjust at all angles....
As for time, do it in evening when things are quiet and you are not in rush to work while day light is wasting...
Also be sure all grinding/filing angles are proper for type of chain... Not all chains use same angles... And the anti-kickback bump is at or below recommended height...
Dale
   / Where’s the best place or way to increase performance with a chainsaw. #13
So chain sharpening is easy... Just kidding..
I did the muffler mod on my 372, I removed the arrestor as well, not sure you would want to do that but it helped, I don’t cut wood in the woods, I cut tree length that a pulp truck brings to me, if I was cutting in the woods I would probably skip the arrestor delete.
What’s a good electric sharpener? The high end Oregon model was like $600. That would buy a lot of chains and forget about sharpening. Btw, my current sharpener works well. I just don’t like it.
My saw goes in the woods some, but I usually do the same thing you are.
   / Where’s the best place or way to increase performance with a chainsaw. #16
Drilled two holes and cut out a small area towards the bottom center with a Dremel tool and then installed a screen in there. Sounds sweet and revs instantly. I can post a picture tomorrow if you want to see it, I just did a Jonsered 2171 which is basically the same saw came out perfect.
   / Where’s the best place or way to increase performance with a chainsaw. #17
Somebody must do good woods porting and mods on the bigger pro Huskys...
i learned what i could watching some youtube vids for the Husky 350's
just for reference here are a couple
husqvarna 340 / 350 dyno runs at the ct gtg 2016 - YouTube
and the dyno charts from the previous video runs
the dyno runs husqvarna 350 challenge - YouTube
the 350 Huskys had a as much as a 3 hp difference up around 11,000rpm between one of the best runners ( over 5 hp) vs. a stock saw which had already signed off power wise and was down to barely 2 hp.
I did some of the mods suggested by a couple of the guys that did vids mainly dropping the crankcase down after removing the gasket (.045 to .017) piston to head in the side squish area and my own muffler mod.
anyone who says just a new- or super sharp chain is right that makes a big difference -
but... put that same chain on an identical appearing saw that is putting out a good bit more HP in the RPM range that most cutting is done and it is just a much faster cutting more capable saw.
i am planning on some more mods this winter - ( installing a flat top piston with new ring vs. the dished piston a original ring) Not sure if I am gutsy enough to port the 350 but I am thinking about it.
I did find some port timing #s posted to start from and I can practice on a new $30 top end kit to get a feel for it.
One thing I am sure of I will never run a stock Husky 350 again.
Actually think I have heard that from other posters - won't run a stock saw after owning a well modded/tuned one.
here is a (fleetcommand) 372 ish comparo
"Spike60 Special" Husqvarna 372 build, Simple Mods That Make A Difference - YouTube
maybe a Bob's spike special:thumbsup:
The 372 isn’t a good lab rat for mods. I might start with my smaller and cheaper saws. I’ve got a $20 dollar polan that whatever happens to it is fine. I’ve got a 353 Husqvarna and a 540 Dolmar that don’t see much use anymore. Getting 5 hp from those saws would be a real game changer.
   / Where’s the best place or way to increase performance with a chainsaw. #19
Tuning the carb just right will make more power and make the saw more pleasant to run.
Carb tuning isn't a set it once and forget it thing. The right tuning changes with ambient temperature- colder air is denser, leaning out the mixture. Fuel affects it too. On old fuel it won't rev out as well.
Like sharpening chains, it's worth learning to do yourself so you can do it when it's needed instead of waiting until you can get to the shop. Once the saw is hot it should four stroke when you lift the saw up when cutting. I don't know about Husqvarnas but Stihl manuals have specs for the idle rpm and free rev rpm so you can use a tach to tune them.
Leaking impulse lines or intake boots or crank seals can cause hard starting and poor running, and can also cause engine damage. It may be worth removing the muffler to check the piston skirt for damage. A clogged spark arrestor can cause poor running too but it's easy to fix by removing the screen and burning off the gunk with a propane torch.
   / Where’s the best place or way to increase performance with a chainsaw. #20
90 octane ethanol free and 90 octane with ethanol is still 90 octane. It makes no difference. If your saw calls for 90 octane, use 90 octane. If you mess with the porting or timing and that causes a predetonation, higher octane may help with that. The only concern with gas with ethanol is storage long term. If you empty your saw after usage and don't let it sit for months at at time, you'll never have ethanol related issues.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2017 Ford Transit 150 Cargo Van (A55852)
2017 Ford Transit...
UNUSED PABREAK SP173-84" SNOW PUSHER (A57193)
UNUSED PABREAK...
Dump bed (A51692)
Dump bed (A51692)
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
