wher is theserial # for an 8n
   / wher is theserial # for an 8n #1
ezzy
tennessee
1952 Ford 8n
I trying to locate the serial # I dont know where to look I was told I had a 1952 ford 8n, if it is I will look for original replacement parts if not I wont worry about it,,,,maybe
   / wher is theserial # for an 8n #2
From the vintage Ford tractor resource:
9N, 2N, and 8N Ford tractors: produced from 1939 to 1952
The serial number is located on the mid-left side of the engine block on an approximately 1/2"x 3" vertical flat. The serial number is hand-stamped onto the vertical flat, not cast into the engine block. Format is model designation before sequential production number. Serial numbers for the 9N and 2N Ford begin with the designation "9N." Serial numbers for the 8N Ford begin with the designation "8N."
web page
thanx I added the web site to my favorites just in case
   / wher is theserial # for an 8n #4
Easy.. left side of engine, just below the head, roughly centered over rear section of starter, and to the right of the oil cannister.
52 8n will have a side mounted distribuitor, 47-50 had a front mount distribuitor. etc.
If you really get into your 8n, check out
N-forum
Lots of 9n/2n/8n specific info
Soundguy
1111-A (A54756)
1111-A (A54756)
1997 International F-9370 Eagle Log Truck, VIN # 2HSFBASTXVC083719 (A57453)
1997 International...
White Metal Roof Panels (A55758)
White Metal Roof...
1994 DOONAN SPECIALIZED TRAILER FLATBED TRAILER (A58214)
1994 DOONAN...
10' Rake (A57148)
10' Rake (A57148)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
