wher is theserial # for an 8n
   / wher is theserial # for an 8n #1
ezzy
tennessee
1952 Ford 8n
I trying to locate the serial # I dont know where to look I was told I had a 1952 ford 8n, if it is I will look for original replacement parts if not I wont worry about it,,,,maybe
   / wher is theserial # for an 8n #2
From the vintage Ford tractor resource:
9N, 2N, and 8N Ford tractors: produced from 1939 to 1952
The serial number is located on the mid-left side of the engine block on an approximately 1/2"x 3" vertical flat. The serial number is hand-stamped onto the vertical flat, not cast into the engine block. Format is model designation before sequential production number. Serial numbers for the 9N and 2N Ford begin with the designation "9N." Serial numbers for the 8N Ford begin with the designation "8N."
web page
thanx I added the web site to my favorites just in case
   / wher is theserial # for an 8n #4
Easy.. left side of engine, just below the head, roughly centered over rear section of starter, and to the right of the oil cannister.
52 8n will have a side mounted distribuitor, 47-50 had a front mount distribuitor. etc.
If you really get into your 8n, check out
N-forum
Lots of 9n/2n/8n specific info
Soundguy
Bush Hog 287 3 pt Mower (A50514)
Bush Hog 287 3 pt...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
