When to use WD hitch
   / When to use WD hitch #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
We just got a new pop up trailer and pull it with a toyota sienna. This new trailer when fully loaded is at the max of the towing capacity of the van. On my truck the towing tables show at what weight to add a weight distribution hitch. The van just says max 3000lb. When the weather clears up I want to take it to a flat parking lot and measure how much sag the trailer causes and how much rise I need on the hitch to level it out. So how do you determine when just air bags or helper springs are needed versus a WD hitch?
   / When to use WD hitch #2
If a mfg writes you need a WD hitch for XXlbs that's my determination to buy a WD hitch. No use having a big lawsuit or getting a ticket to save $150 on a WD hitch.
The van says nothing about a WD hitch that is why I am wondering how to determine if one is needed or not. Or would there be any reason to not use one?
   / When to use WD hitch #4
If your at max weight for the vehicle, then I would reccomend a weight distribution hitch. Worst case, it helps how the trailer handles. :D
   / When to use WD hitch #5
Yes, they add to the hookup process. And if you are OCD getting the balance JUST RIGHT takes more than dropping the hitch on the ball.
I pull a 12K rated trailer with my dually, other than less "oomph" when it's loaded I don't really notice it.
   / When to use WD hitch #6
A weight distribution hitch is a great thing.
I pull a 12k equipment trailer with a K2500 4x4 Suburban, and the "Equal-i-zer" WD hitch makes the pull much safer than it would be without.
You need to determine the proper tongue weight though (10-15% of the trailer GVW).
When loaded, I keep 1200-1250 lbs. on the tongue (yes - I do measure it, and the Suburban has "AirLift" bags.).
   / When to use WD hitch #7
A lot of times it’s what the hitch says. On my F150 it says 500 lbs hitch weight or 5000 lbs trailer weight I need a weight distrubuting hitch.
   / When to use WD hitch #9
The wife's Rav4 says 1500lbs(don't know if I've ever seen a 1500lb with brakes) with brakes and 1000lbs without. I put a hitch on it so our older dog has a step to get into the back but have towed with it. I used it haul my x500 mower which I'm guessing was about 800lbs total just fits on my 5x6 trailer so there's no adjusting tongue weight. The manual just says 9% to 11% tongue weight and I'm sure it was over the 80lb tongue weight but you wouldn't of known it by looking at how much the rear dropped. So I'm guessing that towing on a minivan or car is more based on what the brakes and drivetrain can handle. A weight distributing hitch isn't going to help your transmission. I will help put more weight on the front tires and help braking but if the trailer has brakes even that would only be a benefit if the connector comes loose.
The great thing about a pop-up is you can put the feet down and load it up safely while not connected to the tow vehicle. By using a bathroom scale you can move stuff around to get the tongue weight to about 10% of what you think the total weight of the trailer is. Then you can connect it up to your van and see how much it sags. But you should also load the van (including people) when you do your test. If you want to get a quick idea then just put about 300 lbs on the rear (maybe you with a couple bags of cement or cat litter) and see if it drops much. Most newer cars have the axles pushed as far forward and to the rear as possible to help with stability so tongue weight isn't going to have as much effect as it would with a truck.
   / When to use WD hitch #10
I think you will find a lot of trucks that say to use a WD hitch at 5000 lbs, most people don’t know it. It’s one thing I miss about the 3/4 ton Chevy I traded in, it had a class V hitch and was something like 11,000 lbs.
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
HYUNDAI 740-9 (A52472)
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
