Oil & Fuel When To Change To 80w90 Gear Oil From UDT In The Front Axle
   / When To Change To 80w90 Gear Oil From UDT In The Front Axle #11
This topic was discussed on TBN about 7 years ago.:D And with about the same conclusions. At the time, the manual for my 1999 B2710 had the same recommendation. I had changed it to the gear oil because that's what I was accustomed to for differentials and manual transmissions. It seems that some think the "heavier" oil provides a tougher better lubrication, but then others believed the "thinner" oil would get into tiny clearances that the "thicker" oil would not. Anyway, since the manual recommended either/or and the tractor came originallly with UDT in it, I later changed back to UDT in the front axle.:D And of course I still don't really know whether one is actually any better than the other. But I suspect you'll be alright with either as long as you have the proper amount in there and don't get water in it.:rolleyes:
   / When To Change To 80w90 Gear Oil From UDT In The Front Axle #12
Both are designed to be gear lubricants, the UTF is just formulated to do many other things.
Upside of gear oil is it's thicker viscosity which will provide a better oil film on gears and can help to reduce shock loading of gears.
Upside of the UTF is it's thinner viscosity which will help to reduce operating temperatures. Thinner oils create less internal friction and tend to disipate heat better than thicker ones do.
So which is better, in all honesty either. I use UTF and have never had a problem.
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
78in Quick Attach Smooth Bucket (A57453)
78in Quick Attach...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
17201 (A55852)
17201 (A55852)
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
