Oil & Fuel When to change oil on 2520? First one.
   / When to change oil on 2520? First one. #11
Deadman said:
So is my Rotella 15w-40 good to use, or should I use something else as far as the oil goes?
From what I have read your Rotella 15w-40 will do just fine.. That is what i use in my Dodge/cummins and will be using in the JD for the future oil changes..
brian
Ok Good, because I have a few gallons of it, and just purchased a 07 Silverado with a DURAMAX! :cool:
   / When to change oil on 2520? First one. #13
I would use whatever the manual says to use , as long as it is under warrenty. dont give them an open door if you have engine trouble down the road.
Just my view.;)
I was in the automotive bissiness 28 years. a friend of mine in the early 90"s had a new transam first service he went with some senthetic oil or something. and was running it hard and it blew the motor. now i know the oil had nothing to do with it. but GM did a test and found it had incorrect oil in it. and did not cover it. :rolleyes: he had to by an engine. i seen this more than once. So i am a firm believer to do what thay say while its under warrenty. and there can be no question. after warrenty. do what you like..;)
Chris....:)
   / When to change oil on 2520? First one. #14
I changed at 13 hours to Mobil 1 5w-30. Would use 0w-30 if it were available. The startup vis would still be higher than at operating temperature.
I change it at about 100 hours now or about once/yr. Have a little over 250 hours now. No blue smoke.
Ralph
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A57880)
2001 WORKHORSE...
2019 International Bucket Truck (A55973)
2019 International...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2008 TOYOTA Sienna (A56859)
2008 TOYOTA Sienna...
