When lowering 200cx quickly sounds like air leakage
   / When lowering 200cx quickly sounds like air leakage #1
damiang
Bangor PA
2011 John Deere 2520
I am not sure if i heard this noise before or not so i figured i would ask you guys. When I raise the loader and drop it quickly (but not into float) I hear a what sounds like loud air leak just under my right foot inside the coupling hook up. When i drop it slowly i don't hear it. So i can't recall if that air dis pursing noise before or not. So i am wondering if that is normal to hear that or is there something wrong????
   / When lowering 200cx quickly sounds like air leakage #4
The sound you hear is probably cavitation.
Here is what Wiki says.
Cavitation can occur in control valves. If the upstream pressure is just above the vapour pressure, then it is possible that the pressure will drop below the vapour pressure as the fluid flows through the valve. If the pressure recovers after the valve to a pressure that is once again above the vapor pressure, then cavitation will occur
Does it sound like the power steering noise in a car/truck when at the end of travel?
ohhh good... I just haven't used it for some time and when i jumped on it sounded just a bit loud.. Thanks guys
   / When lowering 200cx quickly sounds like air leakage #6
The temp of the fluid could make a difference.
J J .. the noise sounds exactly like a air hose leak or when you let air out of a tire type.
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
Magnum 125 Generator (A53421)
Magnum 125...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
